New Seamaster 300 weird going ons
Blubarb
Hi all.
This Omega 210.30. Seamaster 300m played up and then resolved itself.  It seemed to be running about 10 secs per day fast. I decided I would check its accuracy by timing it against the atomic clock app. When I fully extended the crown into the hacking position to set the watch I noticed that moving the minute hand also moved the seconds hand. Possible tight canon pinion?
https://
But here is the weird thing: The seconds had "shift" has miraculously resolved itself after a few days of repeating the action. Did I loosen the canon pinion by winding the hands around the dial?  On testing it against the Atomic clock app over the last 48 hours the watch is now running at + 3 secs per day well within cosc specs :thumbsdown:
Can a tight canon pinion cause the movement to run fast? If so how?  Thanks.
Edited by Blubarb
clarity
18 minutes ago, clockboy said:
I suspect the second hand was not seated absolutely straight and was slightly rubbing on the minute hand. After a while it has corrected itself.
That sounds perfectly reasonable, but why the increase in time keeping while that was happening but then returning to "normal"  and more expected time keeping after it corrected?  Could the second hand have been lightly pushing the minute or the minute pushing the seconds at points in the rotation?  You think it would slow it down.
Edited by Blubarb
Could have been an oiling issue on this Cal 8800?  Seems to have settle now.
for what a cheap timegrapher is worth here are some results in Dial up position:
Edited by Blubarb
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
