Ingersoll sealion
Johnnie
Hi Manodeoro, you are correct, it is the GMT Sealion, and again you are correct about trying to find another bezel! The watch runs very well and it is a shame about the bezel, as it completely transforms the watch. I have looked and looked and have come to the conclusion that I will probably never find the correct bezel. It didn't have a bezel when I got the watch, but did have it's original box,papers/guarantee,and receipt dated Christmas 1977. Maybe a spares or repair GMT Sealion will pop up on eBay! Or probably not lol. If anyone has any ideas concerning the bezel please let me know as I have run out of ideas.
I've seen one on catawiki some time ago ... sold for about $100 ... with the bezel
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Indeed.. they make very little money! That's half the problem. I would like to replace the bezel if possible because I feel sorry for it laying there bezeless and old aged ! Somewhere out there is a replacement bezel looking for my watch.
What a lovely old watch!  Can't recall ever seeing another.  Totally 100% agree the red bezel completely transforms it, but yes even with my well-honed Googling/watch findings skills I can only find two other examples 1) that one you mention on Catiwiki 2) one linked on 'Worthpoint' that sold on eBay probably yonks ago:
https://www.worthpoint.com/worthopedia/mens-vintage-ingersoll-sealion-world-251585167
Tough one there mate.  I'll certainly dig this thread out if i ever spot another on my travels though!
Aww thanks Matt, I had hoped to find a bezel, even e-mailed Ingersoll in the hope they may have one but no! They did email back to say "no go" so that's that. Hi Kevin, I fear you are right ! Shame as she's a decent runner too. And so, she will enter the bottom drawer and reside there until I can get a bezel. The good thing is that one could pop up on eBay at anytime! Thank you all for your comments. Best regards Johnnie
There are a few listed on fleabay in the US. Here's a link to one with the correct box just in case you're interested in having that.
www.ebay.com/itm/VINTAGE-INGERSOLL-TRIUMPH-WATER-PROOF-WRISTWATCH-MENS-C1950S-1960S-WATCH/352541824109?hash=item521521546d:g:paUAAOSweX5cD-BX:rk:11:pf:0
The item is in Aylesford.
Hi TexasDon. Many thanks for that, I have seen that watch! I have the box and original receipt so don't need the box... If I needed the box that guy would have a shiny NOS bezel lol.
Edited by Johnnie
Misread earlier comment
Hi again Matt, had a look at that Sealion photo, arghhhhh I must get a bezel, she looks a million percent better with bezel !
Maybe you could try to source just a coin bezel, those with a "paperclip" retaining spring.
If you can get one that fit the case then it's possible to reproduce an insert in red and black with the white writings (not that easy but possible).
Hi Clockboy. I have taken the measurement 31.1 mm and looked on the web... Probably in all the wrong places! Any guidance as to where to look would be appreciated.
Is 31.1 the outside or inside diameter of your missing bezel ?
26 minutes ago, Johnnie said:
Hi Manodeoro, the measurement is of the part the bezel fits into! I can't measure the inner size of bezel as I don't have it. Coin bezel ? Not heard of those, please enlighten me.
"coin bezels" as named from the "coin" scallops around the outer size.
Here are some pics of a paperclip-spring bezel and how it's fitted on the case.
BEZEL (downside) and "PAPERCLIP SPRING"
BEZEL (upside) with the PAPERCLIP SRPING installed in its inner groove
look at the watch case behind ... you can see there is a groove too on the rehaut
Installing the BEZEL on the watch case
the paperclip spring must be fitted both inside the bezel's groove and the rehaut's groove
Check your watch case and if there is a groove deep enough on the rehaut to take a paperclip-spring (if not ... you still  can rework the case on a lathe the make groove deep enough) you should measure :
- the outer diameter of the rehaut (inner diameter of the bezel should be a little larger ... 1/2 mm could be OK
- the diameter of the case where the bezel should sit (outer diameter of the bezel should be about the same)
Then you search for of bezel (coin bezel if possible because it seems the Ingersoll Sealion had a coin bezel) wit hthe right dimensions and that is engineered to be fitted with a paperclip-spring.
If you find one and you can fit it on your watch case I'll explain you how you can rebulid the inser (I'll help you if needed).
For example the bezel below, made for Vostok watches, has a 31.5mm inner diameter and a 39.50mm outside diameter, is fitted with a paperclip spring and can receive an insert (already made or custom made).
Try to find a bezel of the same type with the right dimensions, or have it custo made if you have a mate who has a lathe.
33 minutes ago, Johnnie said:
Hi Manodeoro, brilliant, thank you so much for taking the time to help me. I will try to get a coin bezel asap! Many thanks again. Johnnie
You're welcome Johnnie ^_^ I know very little about watches but everything I know has been learned on watch-forums, so the least I can do is to share that on watch-forums.
BTW ... coin or not coin (meaning the scalloped outside) it aint matter.
What is important is that the bezel is fitted on the rehaut with a paperclip spring, like the Vostoks and/or some Seiko ones ... if my guess (that your rehaut has a groove) proves to be right ...
Would you share some side pics of your Sealion ?
and the dimensions that will lead to the right bezel ?
Edited by manodeoro
Not the best photos I am afraid,  but hopefully good enough???
Not the best indeed [emoji6] but good enough to see your rehaut has a groove.
So now you just have to check the required diameter with a caliper and hunt for the fitting bezel.
Hope you'll find one.
Post the measurements here so that other members can tell if thry see a fitting bezel on the web.
10 hours ago, Johnnie said:
Many thanks again, will measure and do a little diagram as my watch terminology isn't up to scratch!:thumbsd:
What you need is at the least the A, B and C dimensions.
If you have a caliper good enough to check C and D, and even the groove depth it will be perfect.
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
