Clock competition
oldhippy
Still trying to work this one out those Baluster pillars look huge I could only hazard a guess I don't think this is English it dosn't seem to conform to any style of English clock production, its quite late for a verge, I don't think its french being a triple fusee,  i'm thinking Dutch, or Austrian.
All very intriguing and beyond my knowledge, but looking at it raises some questions...
1. I would guess that the movement is not original to the case - I’m taking this from the commentary about the case being gouged out and the state of the back plate. Seems odd that such a complex movement would have originally been butchered into a case.
2. The movement pillars are very decorative and not like those I’ve seen on English clocks. Strange to me that one has been heavily cut away to accommodate the bell hammer arm.
3. The winding holes are placed oddly on the dial, and spoil the look of the hands as they pass over. I would guess this movement originally had a bigger dial
4. All the holes on the backplate suggest the bells have been moved around
All that said, I have no idea where it was made, but I’ll take a punt at France...
I have seen a number of Austrian clocks that have the arched lower case portion with visible pendulum, also the flower motif both on the case and the movement screws appears to have been popular at some point on Austrian clocks I have seen these both carved in wooden cases and as ormolu mounts, And all the German fusee clocks of the period I have seen have wooden movement plates.
The very large baluster pillars I have seen on both Austrian and Dutch clocks.
I would expect it to be older. The seller mentions ratchet wheels and clicks are rough and appear to be handmade. Also mentioned, he thinks is the word “fecit “which means he or she. I would like to really have a good look at it before I really make up my mind. That is all I can say just by going by those few photos. It is a Dutch bracket clock with Dutch striking.
I read a description of dutch striking which is in its self a interesting way of striking, it strikes the hour on the low pitch bell, at the half hour it strikes the next preceding hour on a high pitch bell so at the 6:30 it would give 7 strikes, this I have read came about because of a peculiar way the dutch say what time it is, where we would say it is half past six, the dutch would have said it is half an hour to seven. This clock I believe would be a more unusual form of quarter hour striking I presume on the even lower pitch bell giving one strike at quarter past and one strike at quarter to.
This interesting article gives a description of different striking sequences used in clocks,
http://www.nawcc-index.net/Articles/Murray-striking.pdf
And this page gives a very nice description of Dutch striking and details of a rare repeating Tompion longcase clock employing dutch striking:
http://www.antique-horology.org/_Editorial/Tompion145/DEFAULT.HTM
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
    • I printed the base and it is a bit too large to fit on the base of the hand setter. The ring bumps into the column so it is unable to full seat on the central ring. I'm going to try removing some of the materal and see if I can't get it to go down.
