Clock competition
oldhippy
Still trying to work this one out those Baluster pillars look huge I could only hazard a guess I don't think this is English it dosn't seem to conform to any style of English clock production, its quite late for a verge, I don't think its french being a triple fusee,  i'm thinking Dutch, or Austrian.
All very intriguing and beyond my knowledge, but looking at it raises some questions...
1. I would guess that the movement is not original to the case - I’m taking this from the commentary about the case being gouged out and the state of the back plate. Seems odd that such a complex movement would have originally been butchered into a case.
2. The movement pillars are very decorative and not like those I’ve seen on English clocks. Strange to me that one has been heavily cut away to accommodate the bell hammer arm.
3. The winding holes are placed oddly on the dial, and spoil the look of the hands as they pass over. I would guess this movement originally had a bigger dial
4. All the holes on the backplate suggest the bells have been moved around
All that said, I have no idea where it was made, but I’ll take a punt at France...
I have seen a number of Austrian clocks that have the arched lower case portion with visible pendulum, also the flower motif both on the case and the movement screws appears to have been popular at some point on Austrian clocks I have seen these both carved in wooden cases and as ormolu mounts, And all the German fusee clocks of the period I have seen have wooden movement plates.
The very large baluster pillars I have seen on both Austrian and Dutch clocks.
I would expect it to be older. The seller mentions ratchet wheels and clicks are rough and appear to be handmade. Also mentioned, he thinks is the word “fecit “which means he or she. I would like to really have a good look at it before I really make up my mind. That is all I can say just by going by those few photos. It is a Dutch bracket clock with Dutch striking.
I read a description of dutch striking which is in its self a interesting way of striking, it strikes the hour on the low pitch bell, at the half hour it strikes the next preceding hour on a high pitch bell so at the 6:30 it would give 7 strikes, this I have read came about because of a peculiar way the dutch say what time it is, where we would say it is half past six, the dutch would have said it is half an hour to seven. This clock I believe would be a more unusual form of quarter hour striking I presume on the even lower pitch bell giving one strike at quarter past and one strike at quarter to.
This interesting article gives a description of different striking sequences used in clocks,
http://www.nawcc-index.net/Articles/Murray-striking.pdf
And this page gives a very nice description of Dutch striking and details of a rare repeating Tompion longcase clock employing dutch striking:
http://www.antique-horology.org/_Editorial/Tompion145/DEFAULT.HTM
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
