Clock competition
oldhippy
Still trying to work this one out those Baluster pillars look huge I could only hazard a guess I don't think this is English it dosn't seem to conform to any style of English clock production, its quite late for a verge, I don't think its french being a triple fusee,  i'm thinking Dutch, or Austrian.
All very intriguing and beyond my knowledge, but looking at it raises some questions...
1. I would guess that the movement is not original to the case - I’m taking this from the commentary about the case being gouged out and the state of the back plate. Seems odd that such a complex movement would have originally been butchered into a case.
2. The movement pillars are very decorative and not like those I’ve seen on English clocks. Strange to me that one has been heavily cut away to accommodate the bell hammer arm.
3. The winding holes are placed oddly on the dial, and spoil the look of the hands as they pass over. I would guess this movement originally had a bigger dial
4. All the holes on the backplate suggest the bells have been moved around
All that said, I have no idea where it was made, but I’ll take a punt at France...
I have seen a number of Austrian clocks that have the arched lower case portion with visible pendulum, also the flower motif both on the case and the movement screws appears to have been popular at some point on Austrian clocks I have seen these both carved in wooden cases and as ormolu mounts, And all the German fusee clocks of the period I have seen have wooden movement plates.
The very large baluster pillars I have seen on both Austrian and Dutch clocks.
I would expect it to be older. The seller mentions ratchet wheels and clicks are rough and appear to be handmade. Also mentioned, he thinks is the word “fecit “which means he or she. I would like to really have a good look at it before I really make up my mind. That is all I can say just by going by those few photos. It is a Dutch bracket clock with Dutch striking.
I read a description of dutch striking which is in its self a interesting way of striking, it strikes the hour on the low pitch bell, at the half hour it strikes the next preceding hour on a high pitch bell so at the 6:30 it would give 7 strikes, this I have read came about because of a peculiar way the dutch say what time it is, where we would say it is half past six, the dutch would have said it is half an hour to seven. This clock I believe would be a more unusual form of quarter hour striking I presume on the even lower pitch bell giving one strike at quarter past and one strike at quarter to.
This interesting article gives a description of different striking sequences used in clocks,
http://www.nawcc-index.net/Articles/Murray-striking.pdf
And this page gives a very nice description of Dutch striking and details of a rare repeating Tompion longcase clock employing dutch striking:
http://www.antique-horology.org/_Editorial/Tompion145/DEFAULT.HTM
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
    • glad it worked out, those ESA movements are obsolete but new old stock is still out there, now that you know the make/model you could also do a cross reference to see if something more current would line up with the dial feet and hands...for future use if needed 👍
    • I wish they would have done so in this case. The whole story went like this: I sent my speedmaster to an omega service center about 10 years ago (at that point of time I haven't even started watchmaking). After the watch came back to me it had only about 6 months wristtime until january 2024 (not fair for this nice watch but the other pieces of my collection want wristtime too 🙂). So my conclusion is that the barrel was already faulty when it came back from service, can't imagine that amount of wear in 6 months wristtime. In january 2024 the performance on the wrist was quite bad, so I decided to have a look by myself. I have to admit that I didn't check the barrel close enough as I thought it must be ok, couldn't have issues after official omega service. That was a mistake, I will learn from that. Follow the golden rule: Nothing is certain except death and taxes.
