Hello!
RAG
Hello, fellow watch-maniacs :-D
I am new to this forum and to watches, but for the last few years I have gained an increasing interest in mechanical watches. And where to be then, if not part of this wonderful forum?
May I already warn you now that my posts will not be without weird gramatical inaccurasies - I am not a native speaker but will do my best :-)
- Looking forwards to chat with you all about the best hobby in the world!
RAG
