By way of introduction....
TexasDon
Hi all,
I'm a fan of wrist watches and have been since being presented with  a Longines 5-Star Admiral for graduation. It was entirely too 'delicate' a mechanism for a rowdy teen. It's been replaced many times over with various and sundry mechanical and quartz watches. I have a very modest assortment of daily wearers that range from an authentic Seiko 7S26-0020 diver to a Pulsar Flymaster quartz. I used to do minor maintenance on my watches but not now. As I've aged, the old eye/hand coordination hasn't fared well. Now I will change a drop in battery but not much else. I enjoy reading about watch repair though so I hope to contribute as well as lurk. Thanks for the opportunity to hang out with you.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
