How does this one open?
I’m not sure so this is guess work. A case knife around the red arrow edge. Alternatively, what looks like a Rolex grid mark around the case green arrow, so you will need a case opener that would achieve it?  I do not think it comes out from the front.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
