Help identifying ETA part
AP1875
I need to replace this 2892A2 part
I believe it is item number 25 on the ETA tech sheet
It is listed as ‘reverser assembled’ on the tech sheet but no such name exists on Cousins.
Assuming I’m looking for the correct part? How do I get an ETA part number so I can purchase from Cousins?
https://www.cousinsuk.com/category/filter/eta-esa-movement-parts
Thanks
Edited by AP1875
On 12/5/2018 at 12:57 AM, Nucejoe said:
Hi,  have you checked OldSwissWatches.com  ?
To navigate cousinsuk , cambrige offers courses,  how to get back home alive.:startle:
Regards joe
That's a great site, the descriptions are so much better and the have the part number to match... Thanks
I replaced the damaged parts I found whilst servicing the movement, all was going great until I removed the lower jewel from under the balance. I opened the spring and removed the jewel to my bench split it to oil and PING slip of the tweezers and it's still probably in orbit somewhere... so frustrating.. Anyway can you buy just the jewel or do you have to purchase the whole 'setting'?
I believe it's part number
Inca 09.956.20 Lower Shock Bloc
INCA995620
It's £15 to replace so that could be a costly mistake.
Also I've realised this is a 2892-2 NOT 2892-A2 are the parts interchangeable, ive bought a 2892a2 barrel complete to swap into the movement as I don't have any winders yet...
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
