Seiko SKX 009 Modification
JCStuyck
Hi,
I am trying t upgrade my SKX009 with a sapphire double dome.
I brought a Crystal time 37 BAR. I do have a press.
I did remove the original glass without difficulty. BUT! I am trying to insert the new crystal sapphire in place but it seems that it doesn't get in straight.
I did put the chapter in the right place and the o'ing back in place before positioning the new crystal.
I am afraid to push to hard to get it in place .
Do you have any advice.
many thanks in advance.
J-C
