Moseley 6mm Lathe - Need Collets!
Arthurliu82
Hi All,
Long time listener, first time caller.
I just acquired a 6mm Moseley lathe. Unfortunately, it did not come with any collets. What drew me to the lathe was the cross-slide. I have been interested in getting one for some time and snatched up this package not thinking it could be anything other than 8mm. With that, i am considering keeping it and getting a set of collets to work with. I know there are 6mm lathes made by other manufacturers like Lorch and Boley. Are collets for these machines compatible with mine? Or must i find 6mm Moseley collets only?
Hoping you all can help me in my search.
thank you!
I have an old Hardinge catalog that lists a lot of U.S. maker's collets sizes for watchmaker's lathes (Hardinge has always been a major collet maker to this day). For Moseley "6mm" collets (Moseley no1) they list a body diameter of .240", which is 6.096mm. A Geneva collet in their table lists body diameter as .235" or 5.969mm which is about the right clearance for a collet meant for a 6mm bore (slightly small actually). They list a thread of 71TPI diameter .200" for Geneva and 48TPI diameter .208"for Moseley, the thread for Geneva sounds quite fine at a metric pitch of .358mm- I have a Schaublin 6mm here with .70mm pitch.
So, it's almost certain standard-ish 6mm collets will fit the bore, albeit with a bit too much play for my taste. The drawbar will most probably be an issue but that can be changed, but that's easier said than done. What's really an issue is that the conical portion on the Moseley is 25 degrees, where Geneva (normal) is 20 degrees, same as most 8mm lathes.
You are in my opinion far better off setting this machine aside as a beautiful curiosity, and finding a decent 8mm lathe. Try not to get a Moseley 8mm with the conoidal bore- these take specific collets with a smooth curve instead of an angle on the collet head and those collets are quite hard to find too!
Edited by nickelsilver
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
