Made a Full “How To Make A Balance Staff” Movie
I would think you will have to anneal the old pivot.Although when searching on the net know-one seems to do this.
A book I have suggests that you need to anneal it as well but recommends not to if it can be avoided. As well, the part is so small and the pivot is in the pinion side so very hard to heat. And the new balance was working so well.
a little off topic but here goes I went to machinist school, and I used to think that you blasted a drill bit through steel with high speed, in actuality old drill bits were hand cranked so HIGH SPEED could mean anything above that, now I use the slowest rate I can to drill, 50to 100 rpm,  and I use a mixture of olive oil and dawn dish detergent in a little water, shake it up  each time!!  it work especially well on stainless steel, rate of feed is force, to the object, so if you feed hard or press hard you are heating the bit NOT allowing it to cut but wearing away the sharpened bit, I cant take a COBALT it and put it to stainless with no lube press to hard and it will sit there and spin,  ADD the goo, spin slowly with lighter pressure and you will see curls of stainless coming off the bit.. cobalt its are much larger here in the USA, not for watchmaking, I have only found just steel bits, but the principal applies, I did 3 pivots on and old LaPhare  Moonphase pocket watch  I used 2 bits , the first one I have an involuntary jerk from time to time and that occurred breaking the first one, chucked up another one and hand pushed it against the staff so I could Feel the pressure , and it went in, and YES you may have to anneal if you know all this I apologize not trying to tell you what to do, just my experience
Really appreciate the help. Not sure how to anneal when the pivot is so close to the wheel and leaf gear, pinion.
Sent from my GT-N5110 using Tapatalk
I can recommend carbide drills from eternal tools. See my second to last video on YT, repairing a broken pivot. and you will see They cut through like butter.
Sent from my SM-G950F using Tapatalk
This thread is fast becoming a favourite! Hopefully next you’ll break a wheel and have to re-machine one from scratch, or find a broken jewel as could do with learning that too! [emoji897] [emoji3047]
Thanks Mark. Btw I bought your training session on watch repair and am going thru all the training now. I am picking up tips on diagnostics hear and there, appreciated. I will check out the carbide bits.
I made a jewel replacement video on YouTube a while back. jdrichard01
Mark, these are on eBay. Have you used these in the past.5dffe6989d2ef1d5408d52faa9781398.jpg
I have purchased some from eBay and I found them crap. I then purchased some from Eternal tools and the difference was remarkable. I also have purchased some larger drill bits from Axminster tools which were also very good. As the old saying goes "you gets what you pay for".
Axminster is where I went to school and in the town I served my apprenticeship. I can remember when Axminster Power Tools first started. Now they ship all over the world. They supply the UK army with engineering equipment such as lathes and power tools. The chap that started it all up is now in a home in Seaton poor old boy, such a nice person too.
I think you are right and I may need to pay the high price for a single drill bit. The price of the drill bit is almost the same price of a new part.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
