Is this an 8 day movement?
quantieme
Hi all, this might sound a stupid question but I need to know if this would be described as an eight day movement. I bought this portico clock for restoration as it needed a new mainspring for the chiming train and a new barrel as it had cracked presumably when the spring snapped and as a matter of course I also replaced the winding train mainspring with a new one. It was listed at a local auction as having an eight day movement but I have fully wound it and it has run for 18 days on a full wind so is it a 18 day movement if you see what I mean.
It is at least an 8 day, there are some 14 day movements and month duration
but the 8 day are more common. The nut to hold the bell is the wrong way round. Is there a number on the pendulum? if so is it the same as one of the numbers on the back plate. It has count wheel strike on the back plate. That is a very nice clock. I expect the case is wood. It is a strike not a chime. Is the case made of wood? Many are, some are marble.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
