AS 2066 - looking for information
davidrrd
Hello guys.
So last weekend I got a Rado Musketeer VI with a AS2066 movement. Movement is running quickset seems to be good but the date struggles to change after 24h. I picked up the watch at a flea market in Taipei so it will need a service anyway...... And I am looking for as much information I can in this movement: I found a parts list, now I am looking at a walkthrough/tutorial or some experience that will point me on what not to do!
Iy might take me sometime before I drive in.... But I am doing my homework so I would greatly appreciate any help you guys can give me! ;-)
Thanks in advance.
David 84331eb75a239709c41e2dc09950f1ce.jpg574d4c938722814529a2e3ff74d2dfc0.jpged4a34f824916c396359eb06276d634d.jpg36cafc83b595acbd086249dcc1bc7512.jpg
Hi david.
They are easy to work on., Though the set time and date set mechs are less than perfect good autowinders.Some brands I think Tissot for one still uses as2066 calib( Asian made) which are of slightly inferior quality to Genunine swiss made. I had one with date change problem which bugged me for a while until just by guess changing the jumper did the trick, later I was told the jumper on the watch had  likely to have been Asian made replacement.
First time I see as2066 in Rado, the grade Expectedly is high on it. Drop me a msg when you start working on it, I work with you til fixed.
Regards joe
A kind and generous offer of help as you go along, if you need it, from @Nucejoe :thumbsu:
Perhaps a useful tip if you are working on a particular movement is to reference the ranfft site and be aware of movement IDs within the same family. As you'll see if you look at http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&AS_2066 your AS 2066 comes from a large family! What this means is that if you can't find information on your specific movement ID you might be able to find it for a movement within the same family which will share all the same core components as yours.
As a good example if you search for AS 1900 on YouTube you'll see that Mark has done a very comprehensive service, over three videos, of this movement type. Sure your movement has more capability (automatic and day/date) but at its core it will be the same as the AS 1900.
My other top tip is that when taking off the date dial guard remove slowly and carefully (perhaps even in a small plastic bag) in case the date jumper spring is not securely in place and wants to make a bid for freedom! That is unless you want to spend an hour trying to find it again somewhere in your room. I speak from hard won experience...!
Edited by WatchMaker
Hi david.
Regards joe
Hi david.
Regards joe
Hey Joe,
Thanks a lot for your message and proposition I will certainly get back to you once I start working on the movement. However please be a little patient I have to deal with a couple of things during this month before I can find the time to do it.
This will be my first experience with an AS movement and know little about it's history, but remember getting a message once telling me that they where great movements to learn with. As for the RADO part, I saw messages on a forum claiming there were a lot of fakes and people getting mad at authenticity demands. But one of the apparently "experts" on collecting them said before 1950 (if I remember well) Rado exclusively used A. Schild movements. So I will dig a bit more to see if I find information on this particular one.
A kind and generous offer of help as you go along, if you need it, from [mention=4872]Nucejoe[/mention] :thumbsu:
Hello there.
Thanks for the tips I will be extremely careful there. I've already lost time looking for flying parts and I want to avoid it. As for the videos I am currently looking at them slowly. The thing that is was looking for was on the way to take out the oscillating mass and auto.mechanism that video will help me a lot after that. I've only dealt with ball bearing rotors.
I will keep looking around and will keep you guys posted once I've taken over it!
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
