No luck with movement id...
Haven’t been very lucky with my recent findings and getting them identified.
But I’m not throwing in the towel yet; here’s another peculiar one for you to look at.
Both movement and dial has a symbol ”3” insite a diamond. At least that’s my interpretation of what I see. And the no. 481 is stamped on one of the bridges.
Can’t find any references to the symbol or no. And hoping that someone more knowledgeable can help.
Photos are attached.
And btw. Both balance staff pivots are gone...
30b9a775a53a9fb8e7509bc91afd48f3.jpgy03de66787e7c321557f2aa56dc50f679.jpgff6c3e441cc659c848d793f5988e1920.jpg
Not a bad shout there.  The bridges look pretty identical but the keyless works are slightly different.  Possibly another generation of teh same movement?
Until recently it was possible (but difficult) to view the Catalogue Officiel on Ernst Westphal's site, but they've revamped it and it's no longer there.  These come up on eBay or you can buy an electronic copy.  Have thought about it a few times, but then thought that mostly I'm looking things up because I like the challenges that others set! Other sources may be available, but see here http://www.watchmakingbooks.com/ebooks---pdf-formatted-books.php#!/Swiss-Watch-Parts-Catalog-1955-edition-digitally-enhanced-PDF-eBook/p/19103710
Hi @bsoderling That sure looks like a '3' ... but it's actually a 'Z'. This then makes it a watch made by ZentRa.
Here's another watch by ZentRa with the symbol and the name of the company on the same dial to confirm this: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?13&ranfft&0&2usau&1259164803&
Here's some information on the ZentRa brand in general: https://www.watch-wiki.net/index.php?title=Zentra
This site mentions that ZentRa used PUW, A.Schild or Miverva movements in the main. I also guess that, as a German watch brand, they might have used other German movements which might help steer things in identifying your movement. Are there similarities to a Junghans 680.71 for instance??
Edited by WatchMaker
Hi,
I think we nailed it!
The Ranfft link provided by Watchmaker also mentioned that Bifora movements were used by ZenTra and a quick search on Ranfft fo Bifora point me towards the Bifora 102/1 (without some jewels, just as mine) that seem pretty identical.
So now on to finding a balance staff for Bifora 102 (may not be that easy ...)
Thanks guys for all the help here!
And if you have spare time to waste, there's always my two other id cases alive here on the forum... :-)
Hi,
It’s a bifora 102
LOL! Great stuff! Feel free to spread the love with some 'Like' or 'Thanks' tags! :)
Cheeky blighter! :biggrin: Okay ... when I get a spare 15 minutes I'll have a look for you. No promises mind!
Thanks Watchmaker, I'll try to remember that. Not too used to likes and stuff like that. You're talking to a guy that doesn't even have a Facebook account, if you can believe that :)
And thanks to Busakaz. I presume the catalogue pages are from one these famous Bestfit or similar catalogues I hear so much about? In any case it's definitely my movement in there.
Regarding the balance staff, both Cousins and Balancestaffs.com refer to this as Ronda 370 whereas the catalogue and Ranfft calls it     U 371.
Ronda I know as a manufacturer of many items in this area but the "U" is one I don't have any reference to and would appreciate some education on.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
