cartier cal 83 movement needed
quantieme
They are expensive and hard to get the base caliber is a Frederic Piguet Cal.8310 they are used by Cartier and Ebel watches some parts are available check the wholesale suppliers, whole movements can be found on Ebay but are very expensive.
Sadly its the way of the world, I think the parts are more readily available at U.S wholesalers but complete movements are like rocking horse droppings, I wouldn't buy a Cartier my self, but my partner wanted a Tank watch so I bought her a 1960's manual wind one at least I know I can service and find parts for it, but the modern quartz ones I would give a wide berth, considering Cartier charge £340.00 pounds to service a basic quartz movement.
Thanks for the replies, I had tried cousins but as you say they are restricted, there was a chap on eBay but he has sold his last one (£230) l am pretty sure the problem with the one I have is a broken centre jewel as I took it apart to have a look and it was a bugger to get back together with that magnetic rotor and the wheels being all under one plate. The eBay seller says he might get another in a few months so my customer is happy to wait.
    • Hello and welcome from Leeds.
