Stem doesn't engage back...
Blixen77
My first project based on a 2824-2 clone. I put in and out stem several times but when it seems that the length is the right one when I push the button it doesn't enter.
Maybe pushing it with a tweezer is barbarian and maybe I broke something applying too much pressure? Something I can do without running to a pro crying as a loser? [emoji24]58ea7487302e1d39ca5a536e3cbeb2e9.jpg161f07693d5e0e2a619ab9e1f1f2c460.jpg2cabfc801672a59141cfa1ec55582d7f.jpg
Inviato dal mio LG-H930 utilizzando Tapatalk
Have you tried pushing the little button which, from your pic is just below the crown. Push gently and revolve the stem as you push it in.
Chris I don't understand, there is another button I can try to push to engage the stem? I knew only one that is on the back near the hole...
It would be the same one you pushed to release the stem. Sometimes the keyless works (if not lubricated) will not let the stem back in and require some assistance to engage. Failing that I'm afraid its hands and dial of (again?) Is it the right stem??? From your picture the hands look as if they need re setting anyway....Set at 12.00 just as date changes.
Hope this helps
Chris
Hi blixen, this happens often even with genuine eta.
I don,t think you broke anything, keyless is mostly spring.
Eternaltools.com shows parts and thier names, useful for common vovabualary.
Google brings up diagrams of eta movement.
Chris is on the right tract.
Regards joe.
I have no experience of these Chinese clones but I guess they look like the genuine.
So the little button chrisdt talks about sits at the highlighted blue area, pushing it with a small screwdriver releases the winding stem.
When working with waterproof cases with screw down tubes one have to take into account the fact the crown  has a spring loaded tube highlighted in yellow in the other picture. This is what gives the mushy feeling when you try to push  in the stem in place.
Just gently rotate the stem whilst pushing the release button mostly does the trick when inserting the stem again.
And you must of course take that little spring action in the crown into account when measuring up the stem.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
