Panasonic G7
Panasonic G7 has its own native macro lens. It's a 30mm (So 60mm full frame equivelent). I use it as a regular prime though as I want to get in even closer with the camera further away.
The solution for me was a Viltrox EF-M2 speedbooster and Canon EF macro 100mm and 60mm prime lenses.
Both very sharp buy the 100mm is the most useful to me.
Shoot in 4k and use a 1080p timeline in Davinci Resolve and you will be able to crop in even further. Or shoot in 1080p and use the Ex-tele function on the G7 which effective turns your lens into two primes.
Side note - I recently upgraded to the GH5 and have not regretted it. But the G7 is an amazing camera so I decided to keep it - they compliment each other well.
Hope this helps.
Sent from my SM-G950F using Tapatalk
Hope this helps.
Hi Mark, thanks for the info and prompt reply I'm looking forward to using it.
Many thanks
Kaz
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
