VOSTOK CASEBACK MANDREL TOOL
jimzilla
Hello everyone, I am new to this site and new to vostok modding as well. I hope everyone is having a good evening. I would like to share a little tool that I made today for polishing and or sanding the cases on the vostok watches. I got a little bite mark on the case from the bezel tool when I was taking off the bezel on a 150 case. I want to put a satin finish on or maybe bead blast finish. I have not tried it yet but I think it would be nice to be able to rotate the watch when working on the finish weather you are sanding or bead blasting.
Chuck it up in either a drill press or a drill in a vise and let er rip!.
I got around to trying the case back mandrel out today, I had to use a variac (Variable auto Transformer) to slow down the drill to about 120 rpm.
The speed control on my drill was not working very well.
Here are pic's when I started. I cut strips of scotchbrite into strips held them taught. I was surprised how little pressure I had to use to get the desired effect.
It took me longer to do the sides by hand than it did to do the top.
I think the next time I do this I will glue the scotchbrite to a Popsicle stick. I got a little lite scratching on the side of the case. I think gluing the scotchbrite to a Popsicle stick will make it more ridged and more accurate instead of being so flexible.
It's a great idea and it works well for Vostoks Amphibians who do all share the same back-lid connection. However there aren't  that many watches who are so versatile and have this luxury, that you grab a back-lid-tool which fits many different (style) housings. Plus spare Amphibian back-lids, to make a tool, are cheaply available & in mass.......
:thumbsu:
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
