My new apron, a simple solution.
94marconi
imageproxy.php?img=&key=77f0dcc5ac0f9d5bThe lowly kitchen apron to the rescue. After having spent way to much time on the floor looking for parts and finally bending the pivot on a newly installed balance staff it was time for a solution. Pip to the rescue with his recommended Jacot video by Richard Edwards. While the video was certainly informative on the use of the Jacot tool, it was his use of the apron that caught my eye. Pure genius I thought and raced off to the nearest craft store for a plain white apron with no pockets. After I endured the smiles and jokes from the wife it was time to try it out. Brilliant is all i can say. It simply clips to the underside of the desk with spring clamps and slips over the neck no problem. Easy as pie. I dropped parts all night and not one hit the floor. :) It is easy to remove and I just leave it clipped to the desk if I have to leave for a bit. Probably old news to most of you but hopefully it will keep someone else off the floor and at the bench.:)imageproxy.php?img=&key=77f0dcc5ac0f9d5b picture not uploading for some reason...
Ron
Edited by 94marconi
spelling
Good idea as well. My biggest problem at the bench is my tendency to bring the part to the eye rather than the eye to the part. Finding a chair that goes low enough for the desk is an issue as well. Would like a nice watchmakers bench but would have to give up the roll top desk and I can't do that...IMG_1476.jpg
Finally remembered the photo insertion procedure :)
Ron
Luck is only good for things that fall straight down :) that is true... things that fly know no limits. On my knees with a flashlight is still a big part of the game lol The apron sure helps with the bigger stuff that gets bent when dropped to many times...
Ron
Myself,  I employ a s different approach to the s to the problem with “flying parts”  with a success rate of 6/0 my favor. I use (with extreme caution) a 2X2X1/2 inch Rare Earth Magnet, waving it around, over the floor and flat surfaces until it finds the part. For those that have no exposure to rare earth magnets, they can be outright dangerous, snapping your fingers if you get to close to any mass of ferrous metals.
I am extremely cautious to keep it away from watch and/or tools,  understanding it’s not a mix with watches. But if it’s the difference of finding or losing a part, I go with the less of two evils and have had good luck with the finds.
Photoed below, well away from my work.
Great idea re the apron, I must try.  I use 3 salvaged magnets from (gift) boxes that have a magnetic closure.  These are very powerful and typically the size of cell battery.  I let them attach to a long steel letter opener and use this to sweep around the floor, worktop, clothing and hair!.  I also wiggle it around in the vac cleaner bag before disposal and have later found bits that way!  Just remember to demag the part, as, if it goes again it could attach itself magnetically to something.              For non-magnetic stuff I wrap a length of gaffa/duct tape round my hand and sweep with this, and then inspect with eyeglass, I have found very small end jewels this way.          As with most of us, we probably have the cleanest floor in the house!!
Amen to that canthus I do have the cleanest floor in the house for the very reason as you stated. :) I have not had the need for a magnet yet all though it probably wouldn't hurt to have one on standby...My biggest reason for the apron is to protect things like the balance staff I bent from dropping it so many times on the floor. Those little buggers are getting expensive and buying a lathe and learning it's use are a ways down the road yet. Going to the trouble to learn how to change a staff and acquiring the tools to do so and truing the balance only to discover a bent pivot is indeed frustrating to say the least. Learning to use the Jacot tool is just asking for dropped balances :(
Good to hear other solutions as well as other techniques to the parts on the floor dilemma that plague us all :)
Ron
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
