Chinese movement - tech specs?
Cmmb8519
Hi all,
Wife has this fake Daytona that she loves and has been running for 8 years. I decided to give it a service. Tuff customer!
Most probable a dummy question, but any idea of what movement it is (see photos)? Any chance I can find a tech spec of it?
Thanks! bdbc06fc1f842cd47340556d90291bae.jpga4540d2884d827d7dcba142d79f9653f.jpg
Sent from my SM-G950F using Tapatalk
I'm sure that is a Russian movement. Have you looked under the balance? The other thing to help us, take the dial side plate off and take a photo of the keyless work and upload it. That is the way to id a watch movement that has no markings.
Thanks.
Here you go. See attached.
There are no marks on the plate under the balance or any other marks. Quality seems fairly good. There are 20+ jewels on it. c0e79d8e74347e0a42c3e3bc5377d578.jpg7504818a04b0c7d37113d51d27100b2e.jpg7785ce5a1446490f5af3f9a3ba14ec63.jpgfdb6405f7c286f8449a6e8a2fc30c9bb.jpg
I’d say it’s possible an old Seagull movement - similar to a TY 2869, but without a date dial. Cousins lists a range of Seagull movements here https://www.cousinsuk.com/PDF/products/8164_Sea-Gull 2015 pages 15-20.pdf, but there isn’t an exact match in the current catalogue.
If you look at the dial side cover in on the TY 2869, https://www.cousinsuk.com/product/chinese-movement-list?code=TY2869M you will see the spring holes are very similar. Given the sge of your movement you may find it’s no longer made.
You will note that the balance cock and shock devices are different on yours. Sadly, I don’t know of any resources for positively identifying Chinese movements, or supply of parts, except winding stems. Tech specs are pretty limited although if you can work out the movement number you might find an installation drawin* on the net.  The movements are generally considered to be disposable, but plenty of people do service them, although probably not on a commercial basis.
I think I could be wrong about it being Russian. I was going by the finish of the movement after looking at this photo. If it were Russian the dial side would be the same sort of finish, this clearly is not the case. I have no experience when it comes to Chinese movements, as they were not around in the 70’s or 80’s.
@StuartBaker104 is right on the money that this is one of the Chinese 'TY' series watches. These have the smiley sun and distinct star clustering.
As well as what Stuart has advised, do a search around the TY601. If you look at http://www.watch-tools.de/movements-88/movements/automatic-watch-movement-caliber-sea-gull-ty-601.php for instance this looks like yours.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
