Chinese movement - tech specs?
Cmmb8519
Hi all,
Wife has this fake Daytona that she loves and has been running for 8 years. I decided to give it a service. Tuff customer!
Most probable a dummy question, but any idea of what movement it is (see photos)? Any chance I can find a tech spec of it?
Thanks! bdbc06fc1f842cd47340556d90291bae.jpga4540d2884d827d7dcba142d79f9653f.jpg
Sent from my SM-G950F using Tapatalk
I'm sure that is a Russian movement. Have you looked under the balance? The other thing to help us, take the dial side plate off and take a photo of the keyless work and upload it. That is the way to id a watch movement that has no markings.
Thanks.
Here you go. See attached.
There are no marks on the plate under the balance or any other marks. Quality seems fairly good. There are 20+ jewels on it. c0e79d8e74347e0a42c3e3bc5377d578.jpg7504818a04b0c7d37113d51d27100b2e.jpg7785ce5a1446490f5af3f9a3ba14ec63.jpgfdb6405f7c286f8449a6e8a2fc30c9bb.jpg
I’d say it’s possible an old Seagull movement - similar to a TY 2869, but without a date dial. Cousins lists a range of Seagull movements here https://www.cousinsuk.com/PDF/products/8164_Sea-Gull 2015 pages 15-20.pdf, but there isn’t an exact match in the current catalogue.
If you look at the dial side cover in on the TY 2869, https://www.cousinsuk.com/product/chinese-movement-list?code=TY2869M you will see the spring holes are very similar. Given the sge of your movement you may find it’s no longer made.
You will note that the balance cock and shock devices are different on yours. Sadly, I don’t know of any resources for positively identifying Chinese movements, or supply of parts, except winding stems. Tech specs are pretty limited although if you can work out the movement number you might find an installation drawin* on the net.  The movements are generally considered to be disposable, but plenty of people do service them, although probably not on a commercial basis.
I think I could be wrong about it being Russian. I was going by the finish of the movement after looking at this photo. If it were Russian the dial side would be the same sort of finish, this clearly is not the case. I have no experience when it comes to Chinese movements, as they were not around in the 70’s or 80’s.
@StuartBaker104 is right on the money that this is one of the Chinese 'TY' series watches. These have the smiley sun and distinct star clustering.
As well as what Stuart has advised, do a search around the TY601. If you look at http://www.watch-tools.de/movements-88/movements/automatic-watch-movement-caliber-sea-gull-ty-601.php for instance this looks like yours.
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
    • Ok thanks Ross, I will give that a try!😁
