Omega with plastic case back
LiamB
I have an omega with a plastic case back. I am fairly sure that it's not original and that ithe acrylic glass was added at some point and has cracked around the edges. Does anyone know how to remove this so the watch can be serviced?
Thanks
  • 6 months later...
2 hours ago, marcoskaiser said:
Hello Liam! Please let us know how did it work. I have a venus 170 missing the case back, and started to consider this option.
On the basis that the cost being minimal, and you do no damage by using glue, why not give it a go? I have successfully used acrylic crystals as case backs on several watches that would otherwise have been scrapped.
Phil
Phil
That’s encouraging. I will do so. Thanks for the push!
I could not resist and started to make a case back to eventually fit a sapphire glass. I took an old orient case as raw material.
On the lathe, I gave up mesuring and only listened to the cutting to get hairs off the internal diameter of the stainless ring. Got a fit, but also a question: those of you who made the thing for real, what quality/hardness stainless steel should be used? And is there an optimal angle for the fittings of these click-on backs?
Thanks!
marcos
Edited by marcoskaiser
Accuracy
316L is the standard stainless for watch cases. Around 3-4 degrees for the angles, you don't want a sharp lip though, there will be a cylindrical land. Fitting is of course a bit of trial and error so a good fixture that allows removing and replacing on the lathe without introducing eccentricity is a must
Thanks nickelsilver! I turned a brass holder and left it on the chuck until the end. Only trouble was securing the steel. I used cianoacrylate, and washed it with acetone to release the piece. But heat would melt the glue. Must research some glue for this purpose. Any thoughts?
Best,
I use cyanoacrylate very often, it's super handy. For something like this case I might use a friction chuck, usually plastic (pvc or delrin), that the case fits onto. Typically a short spigot that friction fits an inside diameter and a square shoulder to butt up against. Of course it only holds for light cuts with sharp tooling.
There are fairly sophisticated chucks that can be used but friction chucks are the traditional method, in the past they were generally wood.
Wood is surely more sustainable and cheap than brass...
I noticed that sometimes people like clickspring (makes videos on tooling and clockmaking) use some kind of superglue to hold metal together.
At 6:54, if you get bored...
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.   I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
