ISA 1198 in 2824 case
So I'm putting together parts for my second watch build. I've got a 2824 case in the mail. It would make sense for this one to be quartz because it won't see much wrist time.
So if I purchase a ISA 1198 what problems am I looking at? I know the second hand is a different size. Will the crown fit? Is there any issue I'll run into if I decide to go this way?
isn't the stemheight totally different? Do you have only the case of also the dail?
Manufacturer: ISA
Size (Ligne): 11-1/2 Round
Thickness: 3.25mm
Hands: 90/150/20
Width: 25.60mm
Watch Battery: 395
Jewels: 1
Watch Stem:
ISA1198-STEM10, Tap 10; or ISA1198-STEM08, Tap 8
ETA 2824-2
Features
automatic
sweep second
date: quickset
option: hack feature
Data
11.5''', Dm= 25.6mm, Do= 26.0mm
H= 4.6mm (H= 4.7mm with ball bearing)
F= 1.2mm
T= 1.8mm
17/21/25 jewels
f = 28800 A/h
power reserve 40h
Balance staff ETA 2801
Stem W3738
Mainspring / battery
1.25 x 11.0 x 0.125mm
Hands
1.50 x 0.90 x 0.25mm
The figure you are interested in is "T" which is the stem height. Looks like 1.8mm for the 2824. You'd generally want to get this figure to be a fairly close match for the replacement.
Thw 1198 may come in differnt versions of stem height depending on if it has a date complication, etc. Check the datasheets.
Thanks Rodabod! My ability to access what I need just jumped exponentially. Im going to download the complete website on to my laptop later so if the website goes down I'll have a backup to use.
15 minutes ago, Rattlerviper said:
29 minutes ago, rodabod said:
So in the end it looks like the 1198-103 works. I'll give it a go and if it doesn't work I'll have a movement for a new project.
I think the 103 may be thicker than the 101.
20 hours ago, Rattlerviper said:
1198-103 is 3.7mm high while the 2824 is 4.6 mm high. Does that mean I would need to create a spacer for the back of the movement?
It depends on how the movement is mounted in the particular case.
    • Hi. Thing to do is measure the battery space.  Diameter.  X depth ..    I have seen it listed as  sr626sw.  377 measure to check then check the dimensions of the 377.
    • Hello!  Does anybody have this tool?  This is mine.  If you have one, does it look complete?  How do you use it.  (I have the instruction sheet but it's hard to read!)  thanks!
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
