Fitting A New Watch Stem.
Geo
Question for you guys.  Some of my el-cheapo watches over the years had crown heads which would literally screw themselves off if you were adjusting the watch in one direction.  You could always screw them back on but they'd never fully catch and loosen again if you went to adjust the watch.
Would Locktite do the job?
Yes but not the permanent one.
If you do a search I believe Mark and Geo have listed the number before.
  • Geo pinned this topic
  • Geo unpinned and pinned this topic
  • 9 months later...
I recently figured out you can most conveniently measure up the length of stem you're cutting once after measuring that gap between case and crown, leave your vernier on that measurement and adjust the amount of stem visible in the pin vice to match the depth prong that protrudes from the bottom of the vernier.
Edited by Ishima
  • 2 months later...
Mark's youtube video on replacing a stem worked very well for me as I replaced a two-piece stem, with extension, on a Girard- Perregaux waterproof watch from the mid-forties (Ladies Sea Hawk style. Mermaid?). I ended up cutting it 3-4 times before getting it short enough to be passable, but it still sticks out a bit far from the case. Perhaps I should have used a deeper crown. I think it will pass. I'll post an image once I find a crystal to fit. I did use the bicycle-cable cutting tool, and it worked great, FWIW.
On ‎11‎/‎1‎/‎2014 at 8:21 AM, Geo said:
OOPS, I forgot to say the calipers had to be re-zeroed again!
(5) Remove the calipers and without touching the zero button set them to minus 1.96mm. THEN RE-ZERO THE CALIPERS AT THIS LENGTH The wire cutters are now used cut off the excess thread leaving a small amount to be filed to the exact length.
Please edit this into the original post if possible Mark.
excellent post Geo.  may I add; cut the stem with a cutting disk on your dremel tool.  its much easer to champfer the  end of the stem than the "side cutters"vin
Today I had to cut a stem, but since both my piercing saw and pliers cutter are in storage, I used a cheap triangle diamond file. The job took 20 seconds to complete. For an easy task like this the tool used doesn't really matter much.
  • 4 weeks later...
I'm curious if anyone has the images that were originally part of this thread?  All I see are placeholders now and I have asked Geo if he had them but he replied he didn't.   Seems like a great article but I wanted to see some images for clarity in my mind.
Thanks
Thanks
Prob photobucket ransom. I'd love to see pics referencing this too.
  • jdm unpinned this topic
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
