Fitting A New Watch Stem.
Geo
Question for you guys.  Some of my el-cheapo watches over the years had crown heads which would literally screw themselves off if you were adjusting the watch in one direction.  You could always screw them back on but they'd never fully catch and loosen again if you went to adjust the watch.
Would Locktite do the job?
Yes but not the permanent one.
If you do a search I believe Mark and Geo have listed the number before.
  • Geo pinned this topic
  • Geo unpinned and pinned this topic
  • 9 months later...
I recently figured out you can most conveniently measure up the length of stem you're cutting once after measuring that gap between case and crown, leave your vernier on that measurement and adjust the amount of stem visible in the pin vice to match the depth prong that protrudes from the bottom of the vernier.
Edited by Ishima
  • 2 months later...
Mark's youtube video on replacing a stem worked very well for me as I replaced a two-piece stem, with extension, on a Girard- Perregaux waterproof watch from the mid-forties (Ladies Sea Hawk style. Mermaid?). I ended up cutting it 3-4 times before getting it short enough to be passable, but it still sticks out a bit far from the case. Perhaps I should have used a deeper crown. I think it will pass. I'll post an image once I find a crystal to fit. I did use the bicycle-cable cutting tool, and it worked great, FWIW.
On ‎11‎/‎1‎/‎2014 at 8:21 AM, Geo said:
OOPS, I forgot to say the calipers had to be re-zeroed again!
(5) Remove the calipers and without touching the zero button set them to minus 1.96mm. THEN RE-ZERO THE CALIPERS AT THIS LENGTH The wire cutters are now used cut off the excess thread leaving a small amount to be filed to the exact length.
Please edit this into the original post if possible Mark.
excellent post Geo.  may I add; cut the stem with a cutting disk on your dremel tool.  its much easer to champfer the  end of the stem than the "side cutters"vin
Today I had to cut a stem, but since both my piercing saw and pliers cutter are in storage, I used a cheap triangle diamond file. The job took 20 seconds to complete. For an easy task like this the tool used doesn't really matter much.
  • 4 weeks later...
I'm curious if anyone has the images that were originally part of this thread?  All I see are placeholders now and I have asked Geo if he had them but he replied he didn't.   Seems like a great article but I wanted to see some images for clarity in my mind.
Thanks
Thanks
Prob photobucket ransom. I'd love to see pics referencing this too.
  • jdm unpinned this topic
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
