Black slate clock.
antonyh
I know it's not slate or marble,  but every will know the sort of clock I'm referring to , anyway.
I brought one at a car boot sale, just can't  resist  a broken clock with bits missing, the fact is you always  learn something along the way.
So it's was missing a hand , not a problem,  pendulum,  not too much of a problem with  the fact is you can just pick up a catalogue now days.
And the fine regulator for the pendulum, , well I now now the diffence between the brocot and the vattet suspension system.
So after much searching through my boxes of stuff , I found one and with a little work ,, it's now as it should.
I will get round to posting a picture of the case, but as with a lot of these clocks the cases get damaged easily. .
In the meantime I'm  sure there's a few of you  that will share your pictures.
If the case is heavy, it will be slate. I say this because some cases are painted black and they can be wood. The movement is French, most have numbers on the back plate and sometimes one of the numbers will give you the length for the pendulum. This site will help you with the pendulum.
http://www.m-p.co.uk/formulae/frpend.htm
Just a quick add on for those who are interested in the black slate clocks.
I kept looking at my clock top and back of the clock case, all white in places,  the top was awful where people had put things on, cleaned it with various cleaners,  so it was pretty bad.
So I thought I'd try some of tha Curator, not used it before,  OMG what a transformation.
So easy to use as it's water based, use gloves when your using it.
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
