Fontier Tec Max
chrisdt
Recently  purchased this set from a make offer guy on the bay for a good price.....He says he knows nothing about them or what they do...I probably should have asked before purchase but can anyone comment on this company and the usefulness or otherwise of my impulse purchase. They are described AS NEW
Thanks
