WHAT IS A CHRONOMETER?
 A few weeks ago I began to study Celestial Navigation. At 70 years of age I have no current plans to take off in a boat with a compass, watch and sextant but I had a lifelong curiosity about how navigation  worked  and the  importance  accurate time played in the navigational process.  Most of my working life was spent in manufacturing as a machine designer ( mostly automated machinery) but I also spent nine years (1978-1987) running the CNC department. My interest in watches began, like most people on this forum, as a post career hobby and I plan to keep it that way.  In any case, I was often exposed to the sales hype from the major watch factories  advertising their watch as a "chronometer", at a higher price, as opposed to a general watch which sold at a lower price. The "chronometer" product often had numerous buttons and impressive looking dials that rival pin ball machines, but, as I found out, that was nothing but sales fluff and had nothing to do with the timing device being a chronometer. What actually makes a chronometer  different from other timing devices is  consistency. This does not necessarily mean that it reads the correct time.. A true chronometer  will gain or lose time at a consistent rate and not necessarily tell the "correct" time. If it is to be used for celestial navigation it will come with a  certification certificate showing the  (consistent) rate of gain or loss (fast or slow) over a given time period;  which is typically one month.  This is called  watch error (WE) and must be taken into consideration when calculating a position fix. For example, if the chronometer is four seconds fast per month, one second of time needs to be subtracted from the indicated time for the first week, two seconds subtracted on the second week and so on until the end of the voyage.   A chronometer must never be reset during a voyage due to the possibility of disrupting the timekeeping process.  The precise time is obtained by adding or subtracting the WE (watch error) to the time indicated on the clock or watch dial. Every second of time represents a difference in position of four miles  so losing or gaining a few seconds of time due to  resetting the  clock could be disastrous. According to what I have learned so far,  almost any quartz watch can provide the consistent rate of gain or loss making it suitable to use in celestial navigation.  For mechanical timekeeping devices this is not the case. The mechanical chronometers that were used for celestial navigation in the past were extremely expensive  and still are even if purchased used. Some of them are for sale on Ebay and cost several thousand dollars. That said  quartz controlled electronic devices offer more accuracy at a lower cost and to the best of my knowledge, mechanical chronometers are no longer made.
david
This is a section from the "Official Swiss  Chronometer Site".
 Some German, Japanese, and even non-certified Swiss movements can surpass the normative requirements. The Japanese have largely abandoned the accolade, replacing it with in-house testing to a slightly more strict standard as with, for example, the Grand Seiko. On the other hand, the Germans have set up their own testing facility in Saxony at the Glashütte Observatory [2][3] where the DIN 8319 standards, which mirror the ISO standards used by COSC, are employed. At one time the French provided similar large scale testing at the Observatory at Besançon, however, today only a very few watches are currently tested there and carry the accolade "Observatory Chronometer."
david
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
