Introduction
martint
Hello everyone,
I’m a British expat living in New York at present.
I have been fascinated with mechanical wristwatches for many years and very gradually acquired and performed some basic work on a number of pieces. There is a huge amount of satisfaction to be gained from taking some of these old wristwatches and breathing new life into them.
At the moment, I have a 1973 Omega Genève with huge sentimental value but also a Caliber 89 IWC  and a 1958 Rolex Precision.
Regards,
Martin
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
