Mainspring Sizing
Lawren5
I need to find a replacement mainspring for a Ball pocket watch which uses the Hamilton 992B movement. The broken mainspring measures 2.82 mm wide, 0.16 mm thick/strength and 23.5 inches long. The closest replacement I can find has all the right specifications except that it is only 20.75 inches long, nearly 3 inches shorter. Would using a short mainspring present any problems?
I don't think the 534B will work because it has a width of 3.0mm whereas the broken mainspring measured 2.82 mm. The 534-718047 with a 2.80mm width is the one I've been considering and should work if the shorter length is not a problem.
what was bothering me in the back of my mind is I worked on a ball watch and there were some differences and I just can't remember what they were? then before you remove the mainspring did it seem like there was additional space in the barrel for something wider? It's unlikely that they made a custom mainspring for the watch so it would have to be one of the Hamilton mainsprings. so I'm giving you the complete Hamilton 16 size section so you can see what once was available and what is currently available hopefully.
usually the thicker part of the barrel lid isn't a problem because if you put the arbor in the lid that corresponds to that diameter.
I have an image from the 1946 Hamilton material catalog. Basically were down to they used the mainspring for the Hamilton 992 not Hamilton 992B. You notice in the catalog here when it came to end style both the 534 and the 534B are for motor barrels.
so looking at eBay searching for 992 mainspring keeps coming up with 992B mainspring but I did find a couple in 992 and at least one of them is a white spring which typically makes it newer. The older blued spring is depending upon who made them can hold up and be very nice condition or they can be set and occasionally they get rusty not always noticed by the seller.  Of course getting the white spring means that while you have a whole bunch of choices a very long time ago typically on the modern spring they've consolidated all those choices down to 1  maybe 2  if you're lucky.
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
