seiko 7t32
mrxmttr
cleaning I use hot water and ammonia mix.
Then I rinse in shellite for a few seconds (careful with plastic).
I use moebius 9010 on the quartz gears in a 7t32.
Grease on the keyless sections.
However they are hugely complex and particularly not expensive, replacements are around 60$.
I give up servicing them as its not worth 3 hours of labour on plastic.
7A28 is another story and worth servicing.
I am not a lover of quartz but you can purchase quartz oil. What I can say is use very little lubrication almost what is called ghost oiling. Here is a vid of the 7t32 being serviced. I think this is the movement with an alarm and I had some fun (to say the least) with one a while ago.
I have done just one of these and agree with above - very fiddly. I seem to recall tracking down a service guide online somewhere but it was a while back. They also have a fragile part in the date mechanism which is a very tricky repair if broken. The one I serviced lasted about 2 years before that part then broke and I couldn’t be bothered to repair it so bought a junk Pulsar watch to harvest the movement.
Cousins had NOS movements about a year ago, but all  sold now. If you are looking for a parts donor, the Pulsar Y182 is identical but usually much cheaper on eBay
Thank you all for your advice. I know that a replacement would be cheap and easier than the hours spent on the one I have but I don't do this for profit, it's just a hobby that I enjoy and I happen to have the watch so thought I would give it a try.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
