Tissot Seastar - Refresh and service
Hi guys,
Started to work on the Tissot Seastar I posted below..
I received this watch at my weekend home and didn't have any tools handy so I started on cleaning up the case. (I borrowed the use of a case-back opener from a local store).
Here's how it looks in the beginning, You can see that the chapter ring is separate and has come adrift.
Beginning sanding with some fine sand-paper.. I started with some used 1000 grit..
And progressed onto finer grade.
Getting better.. autosol is my preferred polish..they key is to keep using fresh polish paste and move to a fresh area on your cloth. Otherwise you'll be polishing plastic with plastic.
The bezel cleaned up but theres a lot of scratches...way better than before though.
You can see some scratches but with the naked eye its not too bad. That'll do for now.
One of the lugs had seen some damage.
A little light tapping had it looking better, here the springbars and case have been cleaned and the bracelet installed. I may get around to polishing the rear, more to get the scratches off but I may remove the engraving. I'm in Malaysia and Hebrew words won't help if I decide to sell it.
Hands and dial are pretty clean. Looks like the case kept all the dirt on the outside, kudos to Tissot.
A light coat of dust.
At first glance the movement is nice and clean, it tries to tick .. hopefully a clean and service will see it right. I'm a bit cautious with these Tissot movements as I have had a few problems with these movements (2571). For one thing the centre wheel pinion where the seconds hand goes is quite fragile. I have broken a few.. probably because the hand-puller was not absolutely at right angles... but I dont have this problems with other watches!. Also the I have broken the Inca spring on a few Tissots but never on any other brand of watch. (KIF are another story!). Perhaps its just co-incidence but as a result I remove hands and balance jewels with extra care!
coming up.. servicing the movement.
Anilv
ll I took a few pictures during the strip and rebuild..
First the automatic weight comes off..
Then the automatic module.. simple enough. Note below that tone of the screws holding down the autowinding mechanism also holds the winding wheel in place.
With the automatic weight off the watch tries to run..
Now I flip it over to work on the dial side..
Everything comes apart well. The set lever bridges is intact. The quickset lever is also present, this can go missing as its not immediately recognizable in the parts tray!
Back to the other side to get the train and barrel off..
A naked mainplate
I didn't get a picture of the wheels.. sorry.
Here's a picture of the movement re-assembled. In this case theres not much difference before and after as the case did a good job keeping crud out!.
And here's a video.. happily ticking away!
Anilv
Edited by anilv
  • 11 months later...
3 hours ago, tmag101 said:
My Tissot 'Seastar Pr 516 GL looks like this one.  Mine seems to run when worn but. the time is tough to set and date does not set..  Am I into a large repair?  Or is it as easy as a winding stem?
A regular service should do. BTW, we have a section were it's considere polite to introduce oneself, and please don't unnecessarily hook into existing project topics just because you have a same  watch.
Edited by jdm
What a surprise seeing this model and face on here right as I'm getting back into this after a break. I've got the same model and I've always had a hard time finding ones exactly like it with the same color combination. I haven't done a full service of it yet but I have replaced a loose cannon pinion. The push-in date set complication has given me the most trouble of any watch to date, which is probably why I haven't taken it fully down for a service. It took me 4 or 5 tries until I got it together without something slipping out stopping the date advance from working.
Great work!
  • 3 years later...
A naked mainplate
Anilv
Anilv, sorry to resurrect this post but I just acquired a Tissot Seastar with the same movement (actually the 2591 US equivalent). But it came in pieces as the seller appears to have taken apart the dial side to clean and messed up by removing 95% of the calendar day and date wheels printing and seemed to give up. I think all the parts are present and currently looking at the parts list to cross check. But can't find a service manual that shows an exploded view with oiling scheme that would help in my assembly
 Normally I have the luxury of taking pictures of the disassembly but as I said that it came in pieces. I think your pictures will provide me with enough to assemble the dial side again. Anyone know of an oiling chart or service manual (not the parts list) that could assist?
Thanks in advance, Razz.20230727_2027202.thumb.jpg.6931e4ddeb054cd4ace9e87bbeb12dde.jpgDSCN54192.thumb.JPG.f771e60e036dfda929591ae033ff78a4.JPGDSCN54202.thumb.JPG.5bb6be99df0b47c0eaad39db5b94a698.JPG
Original dial, case and back, bracelet, hands and signed crown all seem in decent shape and the goings side looks to be intact and free but not running.
I can already spot that the seller has the wheel with the 3 lined screw upside down!
Edited by Razz
On 9/5/2023 at 3:53 AM, anilv said:
Hi Razz,
Sorry for the late response... don't frequent the forum as much as I used to.
Hope the rebuild went well!
Anilv
No worries Anilv! Thanks again for posting your pictures as it was enough to get me in the right direction. The rebuild went well and I am so happy with the result. I will eventually post the rebuild either here or in a new thread and post the link here so others can find both. I really learned a lot about this family of calibers and picked up another 2591 and had a 781 to use as a donor for some parts until NOS came in. Particularly the pallet and its Bridge. Also had the source a minute wheel (broken teeth) and the day and date rings. Have a new mainspring but you can see rhat the center coil is much too large for the arbor. I was able to service the old one so did not need one to get it running but got one anyway because the amplitude is low. Also needed a minute train bridge screw. I still need to put the finishing touches and asjustments but this one really wears nice on the wrist and runs well!DSCN55172.thumb.JPG.4360586c969bddbcd148456e5f6c0777.JPG20230825_0751022.thumb.jpg.081d801124a862adcacd579d24e82a2b.jpg20230825_1508212.thumb.jpg.ff765e838c725549fdb17bf11fa7e5ea.jpg20230825_1509132.thumb.jpg.7919decc11240d2d3f451748e6333c33.jpgDSCN54853.thumb.JPG.8229ce3630766731626780a833f98d9d.JPG
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
