555.415 interchangeable?
I have a Tissot with a ETA 555.415 movement, that is water damaged.
I have decided to replace the movement, as the ETA movement is pretty low cost.
But the 555.415 is not as easy to find, as some other ETA movements.
So my question is, is there other ETA models that are directly interchangeable with the 555.415??
Dennis.
3 minutes ago, GleaveandCoLuke said:
The correct replacement for this is not 255.112.  This is the wrong diameter and thickness.
555.415 = 955.412, 955.412 is the same movement essentially just a few updates over many years.
decisions, decisions....
My bad. Didn't do my research properly there.
Hope i am right this time. Three first are for day at 6 a clock. if you have the date window at 6. Last two is different heights. On the H1 the hour wheel is 1,06 and H3 hour wheel 1,55.  There is also a H0 https://boley.de/en/caliber/watchmovements/eta/4001.955-412
Edited by rogart63
Good work Rogart! I fear this may become a lop-sided effort...... @Emancipator are we being of help here?
J
Edited by noirrac1j
Follow these steps...
Does it have a second hand...  Yes = 3 H = 3 Hands, No = 2H = 2 Hands
Where is the date...   At 3 O'clock = 3D, at 6 O'clock = 6D
Remove the old hour wheel and measure the height with a vernier gauge, if it is between 1.02 and 1.10 then it is normal Height.  Otherwise you will need a high or low version.
75% of the time you will have the most popular version which it 955.412, 3H, 3D  (Normal height, not HT0 or HT3)
So that is 955.412, 3 Hands with the Date at 3.  Suppliers all round the world will stock this version.
Simples :-)
Simples :-)
The movement i am replacing is has a H1 hour wheel, so that is sorted.
I must be slow... because the difference of D3 or D6 movement is obviously what direction the numbers on the date ring has. :hocky:
Thx.
Dennis.
Thx.
Dennis.
Hey There @Emancipator. No you're not slow...it takes a little time to figure such things out. Check out @rogart63 explanation of the movement codes.
J
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
