Greetings from Gothenburg
Oboegeoff
Hi everyone!
I'm an English professional oboist living in Gothenburg, and have an interest in mechanical watches. Through the years I have owned some lovely - mostly mainstream - watches, Omega, IWC, Rolex etc. At present I have a beautiful Dornblüth centre seconds as a one and only, my son having taken over my modern Longines dress watch and my vintage Omega Dynamic... IMG_0564.thumb.jpg.6fc332aba150903cfce9a3787f6c53b9.jpg
My interest in the mechanics inside our watches led me to the Timezone school a few years back, and I did the first two courses, which I loved, but real life intervened as it sometimes does, and my tools ended up in a packing box... But now with things more tranquil on the domestic front it's time to dust off my stuff and get back into the wonderful world of watch movements...
I look forward to chatting with you all here, and hopefully absorbing plenty of advice and inspiration.
