  • Similar Content
    • By sunday
      Hello, I'm building a watch using a Sellita SW200 and I bought an ETA 2824 dial.  The dial has four feet and so does my movement, but they don't line up, the ones on the dial are too far apart relative to the movement.  I think if I cut off two feet I can make it fit but I'm not 100% sure.
      Is this a common scenario?
    • By AdamC
      Hello,
      I know this is a long shot but would anyone happen to have the technical sheet for the ETA 1164. I acquired this little beauty on ebay; a non-runner from the USA, which needs a lot of TLC. I've never tackled anything quite like this one but fancied the challenge. However, I'm not 100% sure yet whether the everything on the bottom plate under the dial is complete - can anyone confirm? The top plate however looks fine. The watch back is stamped "Seeland Watch Co. Swiss" - having looked it up, it appears Frederick Seeland was once CEO for IWC! Nice historical timepiece once I've restored it. I've added a few photos for reference (yes, I've removed the balance ).
      Thanks in advance.
    • By AdamC
      Hello,
      It's been a while since I've posted but I have an issue that's perplexed me! About ten months ago, I repaired and serviced a rare ETA 2832 movement with a day date calendar mechanism. The watch worked fine until recently when the day wheel advanced half way and then got stuck. Having had it back on the bench and done a partial strip-down, I have re-engaged the day wheel, which now turns freely through all days in the crown/stem corrector position (as does the date wheel when turning in the opposite direction) but when moving the hands forward through 24 hours, the date wheel advances but the day wheel will not. I have carefully examined the day jumper mechanism and note that as the calendar wheel rotates and the arm engages the teeth and rotates the date wheel, nothing seems to be engaging to move the day wheel forward. I have added a few photos which may help to identify the problem. I have annotated with a red arrow, the lever which I think is supposed to advance the day wheel but doesn't engage at the calendar wheel teeth (if indeed this is what it's supposed to do). Any ideas of what I may have missed here?
      Thanks
    • By AdamC
      Hello,
      Thanks
    • By AccidentalWatchmaker
      Hi all,
      I'm currently building a custom watch with an ETA 2892-2 movement. The movement is from an old Brietling. I managed to fix it and was working perfectly. I was in the process of putting it all together, was attaching the second hand and it suddenly stopped. I believe I may have used too much force. However, I have taken the watch apart again (about the 12th time!). I notice that when I move the hacking spring it stops as it should, but when I return it to the position that would usually allow the movement to move again it doesn't. I assumed I'd knocked something out of alignment, but to add to the confusion if I give the escape wheel the slightest nudge it continues ticking. It's baffling me.
      Anyone have any ideas?
      Best,
      Dan
    • Two eBay vendors have told me they are not interchangeable so I guess that is the answer.
    • Wives always think we have problems. Welcome.
    • Pictures  would help..most likely  it is a snap  on back which you pry off.most likely  the rotor is loose  or severely  worn. Others may know better, but you probably  could just remove the rotor and use the  watch as manual  wind only. Other possibilities  include  a donor  watch to swap movement  or get parts.
    • Hi, I guess I’m a watch collector. My wife thinks I may have a problem. Anyway I want to learn how to do some minor repairs and maintenance. I just happened on this form and am excited about it. I’ll go over the rules and be a great member. I live in Bessemer Alabama and work as a registered nurse.
    • the watch was serviced, not manually wound then purposely not worn overnight to check the wind down time, so if you ask me habits did change esp since he was sick and was not moving much. Now if he manually wound it and it did not run overnight then i would say without a doubt there is an issue with the service. I don’t think its wise to just automatically jump to service as the culprit, I like to give the professionals the benefit of the doubt.   BTW Bauertime sorry for your loss - you will be in my prayers tonight
