  • Similar Content
    • By AdamC
      Hello,
      I know this is a long shot but would anyone happen to have the technical sheet for the ETA 1164. I acquired this little beauty on ebay; a non-runner from the USA, which needs a lot of TLC. I've never tackled anything quite like this one but fancied the challenge. However, I'm not 100% sure yet whether the everything on the bottom plate under the dial is complete - can anyone confirm? The top plate however looks fine. The watch back is stamped "Seeland Watch Co. Swiss" - having looked it up, it appears Frederick Seeland was once CEO for IWC! Nice historical timepiece once I've restored it. I've added a few photos for reference (yes, I've removed the balance ).
      Thanks in advance.
    • By AdamC
      Hello,
      It's been a while since I've posted but I have an issue that's perplexed me! About ten months ago, I repaired and serviced a rare ETA 2832 movement with a day date calendar mechanism. The watch worked fine until recently when the day wheel advanced half way and then got stuck. Having had it back on the bench and done a partial strip-down, I have re-engaged the day wheel, which now turns freely through all days in the crown/stem corrector position (as does the date wheel when turning in the opposite direction) but when moving the hands forward through 24 hours, the date wheel advances but the day wheel will not. I have carefully examined the day jumper mechanism and note that as the calendar wheel rotates and the arm engages the teeth and rotates the date wheel, nothing seems to be engaging to move the day wheel forward. I have added a few photos which may help to identify the problem. I have annotated with a red arrow, the lever which I think is supposed to advance the day wheel but doesn't engage at the calendar wheel teeth (if indeed this is what it's supposed to do). Any ideas of what I may have missed here?
      Thanks
    • By AdamC
      Hello,
      Thanks
    • By AccidentalWatchmaker
      Hi all,
      I'm currently building a custom watch with an ETA 2892-2 movement. The movement is from an old Brietling. I managed to fix it and was working perfectly. I was in the process of putting it all together, was attaching the second hand and it suddenly stopped. I believe I may have used too much force. However, I have taken the watch apart again (about the 12th time!). I notice that when I move the hacking spring it stops as it should, but when I return it to the position that would usually allow the movement to move again it doesn't. I assumed I'd knocked something out of alignment, but to add to the confusion if I give the escape wheel the slightest nudge it continues ticking. It's baffling me.
      Anyone have any ideas?
      Best,
      Dan
    • By AdamC
      Hello,
      I have been asked by my stepfather to service his Sanford Bros HF 36000 automatic watch bought new in 1977. On starting work, I noticed its an ETA 2832 but on looking for the technical sheet, I can't find one anywhere. Perhaps it is a rare movement but maybe there's an equivalent document I can use. My first main concern after removing the rotor is how to remove the auto-wind assembly - looks quite complicated and this is only my second attempt at an automatic movement. I've added a few photos for reference. Of interest, Sanford Bros was a small watchmaking company in the '70s based at 321/323 Oxford Street, London W1. He still has the original sales invoice!
      Would anybody be able to point me in the right direction please?
      Many thanks
    • Hi all,   I'm new to this fascinating discipline.   I'm a plumbing and heating contractor by trade.   Been in that industry for 35 plus years.   My other interests include gunsmithing.   I stumbled on to one of Marks YouTube videos and I was drawn right in.   I've always been interested in mechanical things.   Thanks for all of the information I've already received.    Hope to pursue this and gain skill and knowledge.
    • Hi JDM, This is super consolidation work. Huge help. Thanks very much.
    • I had the same problem on a pocket watch. Turned out to be a loose impulse jewel. Re-shellaced it and all was good. Sent from my iPhone using Tapatalk Pro
    • Look at the spring position BETWEEN the regulator pins.  If its central to both pins, I vote to leave it alone.  The old guys (Fried and De Carle) often suggested using a slight bend in the hairspring  to centralize the spring position between regulator pins.  It does appear to be a little eccentric.   At any rate, I doubt your slight kink would be a reason for low amplitude.   Good luck, RMD
