Screw extraction (broken screwhead)
IFELL
Hi,
I managed to brake a screw which is holding the movement in the case.
Now, I don't really want to buy the dedicated Burgeon remover (~ £70), are there other ways to get it out?
The screwhead went completely off so I am left with just the shaft of the screw deep inside the hole.
I found these precision screw extraction drivers. Anyone has any experience with these? Are they small enough?
https://eustore.ifixit.com/en/Tools/Drivers-Wrenches/Precision-Screw-Extractor-Set.html?cur=1&utm_source=google&utm_medium=mc&utm_campaign=gshopping&gclid=CjwKCAjw39reBRBJEiwAO1m0OaeDhACGsOqhgZnLzupVcHbStZSTnsmvOMKcmOgg7A1dAOpEmdIvCRoCoWwQAvD_BwE
Thank you for any tips for other tools or techniques.
You can sort of replicate what the Bergeon tool does with a staking set, get a stump and punch that will both fit in the threaded hole, and clamp the screw between them, then turn the entire mainplate around the screw. If the screw is really stuck it doesn't work so well, but generally once the head is broken off they have some freedom in the threads.
Ok,
I mount my soldering gun on a stand and heat up the screw only with it.
Meawhile fix a jar of cold water mix with bunch of ice cubes.
The water cools down as the screw heats up, at highest temp I drop quench the plate in the water. Reheat the plate let cool down to room temp, drop penetrating oil on the screw, come back next day to attack the mess I done made.
If it didn,t work, I blame it on vinn.   :geek:
Regqrds joe
I don't know if it is my method (Probably is) but I have had not much luck using alum. Those screw extractor screwdrivers look good I mighty give them a try. I have the Bergeon screw extractor and have used it once. The method I have used is to drill out the old screw after flattening the broken screw head. This method has it's dangers IE is f the drill wonders off centre and only works with screws large enough to take a drill.
20 hours ago, Nucejoe said:
Ok,
Regqrds joe
     i'll take all the resonsability,  IF  the proper penetrating oil was used.    vin
I have not seen much less use alum, but regard it credible since OH introduces it.
I would say, what time and other costs I would put in, much depends on the piece,  not just the material but the price as well.
The thremal expansion of the screw and pursuent contraction,  is to facilitate the peneteration of oil, as the heat if much conducted to the mainplate is to be transfered through the rust between the screw and the plate, that with the following contraction, breaks possible rust or other chemical bonds formed beteewn screw-plate.
Quenching is not expected to play a major role.
With all due respect to repair masters ,over all, oiling approach is superior to chemical dissolution of the screw, since gold or chrome plating inevitably  got pores to make the mainplate vounerable to penetration of  chemicals, or tapping on the screw from both ends, since tapping would damages the thread in the mainplate too.
So if is a rolex or vacheron  , I would do at most to affect the screw only. if an Asian eta ...well.
Regards joe
I have been successful using vinegar  (ascetic acid), it eats the steel just make sure you don't get any important steel bits submerged as it could damage them as well, leave it in the vinegar over night or until dissolved.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
