Showing results for tags 'wind-up'.
Found 1 result
  1. Hello there watch fix fans. Here's (I hope) an interesting one for you. I have this beautiful small ladies 'Fero Feldmann' Swiss-made watch - it came in a bag of "used and to be repaired" watches. From what I can see, the mechanism seems in very good working order. Just a slight shake and it goes and goes. There is no strap, but that is not the issue here. The problem is the stem and/or crown. As you can see, there is definitely no crown. But I am wondering about the stem. The watch does have its case and edoes have, as you can see, a hole where the stem and/or crown will/should fit in. There is something which appears to be some kind of part-stem at the 3 o'clock position. Using tweezers I can pull it out and push it back in quite freely. A very small screw on top holds this "stem" in place. I think you can see, in ths second photo, how this "stem" attaches to the rest of the movement. Clearly I need to attach a crown. BUT what about a stem? A stem extension? Or one of those crowns which has an extended stem-like attachment which should fix onto this current "stem" in this watch? Yes, the watch face is somewhat scratched, and the minute hand is a little bent at the top. You may say it is not worth my while trying to get this fixed. But I just SO MUCH like this little watch and would LOVE to give it life again! It clearly IS still "alive" - though I'm not sure if it is a mechanical wind-up or an automatic. The latter of these seems to be the case - as I said earlier, a little shake and the mechanism goes and goes. PErhaps with a little oil (and lots of encouragement) it can be made good. So my main question - what kind of stem/crown to attach and how to do it?
