So I'm in the midst of my first ground up build and am (unsurprisingly) having some issues. I swapped the stock white day/date wheels from my NH36 movements for black ones to better compliment my dial. I then tested the functionality before putting the dial on and all seemed to me working correctly, however once the dial was on I discovered an issue. The date wheel isn't quite lining up correctly. Here's the weird part: when I use the quick set function they line up fine. It's when I set them via turning the hands (which I was doing in order to determine 12am so I could install my hand set) that the date clicks in place a little high. Also if I have the date set and lined up correctly via the quick set function and pull the stem out to the hacking position the date wheel moves and misaligns. Any ideas of why and how to fix it? Thanks!
