Showing results for tags 'opening a case'.
Found 4 results
  1. Apologies for the incorrect lingo. My watch is this model: Hugo Boss HB-286-1-14-2893 And some pictures here: https://imgur.com/a/Y9lawhR I do not mind getting some tools myself to to this. And if possible, I would like to know where to buy a replacement back cover and straps, as they are pretty worn out.
  2. Hi, Picked this up in eBay for $15 and overall a pretty nice restoration project. First problem however is getting the movement out. I've looked under magnification and don't see any way to slip even a razor blade between the caseback and case, so I'm assuming the movement comes out some other way. I've tried lifting the cystal off with my crystal remover but abandoned this for fear of scratching the case. I've looked through the forum for advice, did see one thread about Benrus in general but honestly couldn't follow it and not sure it applied to my particular watch. Any help would be greatly appreciated since once opened and cleaned and returned to the case, this shoudl be a sweet little vintage piece (the band is original as well, mark Benrus 1/20 GF and in excellent condition).
  3. Greetings all. I recently acquired a moderately old Benrus 3-Star Automatic wristwatch. It's a #7026 Series. I believe these are from the 60's - though I don't know much about them. On the back of the case it says "open through crystal". Which makes me think that the Crystal should be removed using a Crystal Lift - and the movement lifted out through the bezel. Of course, the stem (presumably two-piece) would have to be separated prior to - or during the operation. BUT - after some googling - I have also heard tell - that the case-back should be pushed out by pressing on the crystal with thumbs. These seem to be incompatible methods - but I really have no idea - as I have never seen a case like this. Does anyone have experience with this type of case from Benrus? I can post pictures after I get home - if they are needed. Many thanks! -Paul
  4. Hello once again. I have this YSL 5421 quartz watch which wasn't opened for about 10 years and I just can't open it, since I am not sure whether I should force it or is there any trick that I can't see how to open it, and I rather ask you how to go about it. I have the knife and a watch pray type opening tools, but this back seems to be shot real tight and hope I won't have to buy the $100 case back opening tool at this stage of my hobby, although Since we are on the subject I would love to know which one you think better or preferred for future consideration. Thank you
