Showing results for tags 'hand made'.
Well its been a while since i shared a post and i thought id share a mini project with you splendid folks as i know you all like looking at new and shiny things Ive spent several months working away almost non stop on various repairs and services, so when i finally had a chance to clear my table i figured id get stuck into a small project idea i had. When i set out with a specific idea/design in mind i usually write down every dimension and draw up diagrams and spec sheets etc, but i figured for this project id just play it by ear, or eye in this case. I was working on a pocket watch movement when it occurred to me how boring ( although reasonably functional ) my movement holder was, and i thought to my self why not make my own. With some metal stock lying under one of my cabinets i got to work and just lost myself in my machines........... Top corner is my trusty albeit ragged holder, with parts machined by eye underneath..apologies for lack of focus After a clean up and light polish ( lets not go too crazy it is a tool after all ) i got round to assembling the holder and setting the bar shims and threads with some Loctite > As you can see i didn't go too crazy with the finishing of every piece as it is going to be put to work but i think its an improvement over the standard el cheapo i use for large movements. As i used thicker parts overall , the holder is much more rigid Im sure i will likely be making some more in the near future but im going to design them next time rather than play it by eye I do like Bergeon Holders but nothing quite beats something you made for yourself . Next project is a new tweezer/forcep stand for my trusty Dumonts ( For those interested in boring details > M4 Threaded centre stainless steel > 12mm Free Machining Brass Knurled knob & retainer screw > 6mm Brass shims > 4mm Brass sliders with M4 threads 3mm long >2 x Aluminum flat bars machined in mill and hand finished angle ZZZzzzZZzz )
- 16 replies
- 6
- tools
- movement holder
(and 2 more)
Tagged with:
