Showing results for tags 'ground loop'.
More search options
  • Watch Repair Tutorials & Information
    • Chat About Anything Here
  • WATCH REPAIR DISCUSSIONS
    • Your Projects, Walkthroughs and Techniques
    • Watch Repair Tools & Equipment
    • Watch Repair Gallery
    • Clock Corner
  • OTHER RESOURCES
    • Watch Technical Data & Service Sheets
    • Watch Repair Videos
    • Directory of other Horology related websites
Categories
  • Watch Repair Basics
  • Balance & Escapement
  • Watch Movement Servicing & Stripdowns
  • Quartz Watch Repairs & Service
  • Fitting Watch Jewels
  • Machining & Turning
  • Clock Repair Videos
Categories
  • Watch Repair Techniques
Categories
  • Watch Servicing & Repair
  • Clock Servicing & Repair
  • Watch & Clock Making Books
  • Other Horology Related Books
Website URL
Found 1 result
  1. Hi all, I'm using WOS 1.3 and I like it very much. I had some problems (freezing oscilloscope view) on a particular laptop (Lenovo with Realtek soundboard) so I moved it to an Asus Laptop; no more problems. I noticed that my old Timetrax ticking sensor was picking up a lot of noise from the surrounding ambient, surely related to 50 Hz mains and other sources, like LED lights. I looked at the cable connections: There were only one "hot" wire and a shield, connected to both the piezo ground side and the plug ground side. That creates what Audiophiles call a "ground loop", acting as an antenna to pick up the noise. So I replaced the cable with a good quality shielded Microphone Cable, with two wires inside and a good shield. The shield was connected ONLY to the plug ground side, and left "floating" at the sensor side; that's the important trick. Now the noise is reduced to near zero; I checked with an oscilloscope, and by hearing it at the output of the Timetrax amplifier. Hope that this will help some of you, Paolo from Italy
