Showing results for tags 'chinese clone'.
I'd really appreciate your opinions on the following. I've just started the "Level 2: Maintenance Servicing" course on https://www.watchrepairlessons.com. Before this I have successfully serviced about a dozen Russian Vostok movements (2409, 2414, 2415) so my choice of movement for following the course is probably not critical as long as it is a manual movement without any complications. Anyway, I wish to follow along as closely as possible so I've decided to pick up the same kind of movement as used in the course. My idea is that once I'm finished with the course I will build my own watch around the movement like Mark Lovick shows in this video. Now, I can't make up my mind whether to buy a Chinese clone like the one in the image above available on cousinsuk.com (CODE: CHI3620M) and of course on eBay (I suppose) or... whether I should go with the above "Nastrix" movement found in a pocket watch on eBay. To me the "Nastrix" movement looks "more attractive" (I wonder what alloy that is?). I think it would look better inside my own watch as I have a glass case back in mind. I have negotiated the price to about £61 for the Nastrix which is quite a bit more than the £36 for the Chinese clone. The following info is from the ad on eBay, and from my mail correspondence with the seller: " (---)in pristine condition--never, ever used. BRAND NEW!(---) This has the highly reliable, full size ETA6497 movement. (---) Movement is approx. 36.70mm; that would be American size 8; 16 lignes. Case is 48.95mm approx. The movement is stamped "Nastrix Corp, Seventeen Unadjusted", and "17 Jewels SWISS". If you look inside this watch at the movement, you will find that it is a 17 jewel incablock made by "Nastrix." These were made by a man called Claude Wollman in Swizterland between 1970 and 1990. Arnex was the name of the manufacturer. Other good names which exist for these watches are Neiman Marcus, Kellner, La Cloche, Bucherer, and others. There is a good article on these watches which you can find on Google called "What is the value of an Arnex Pocket Watch." The article is not exactly clear about the cases. But the parts are Swiss and under a special treaty to keep US labor in the US they may have been assembled in the US Virgin Islands (St Croix.) A most convoluted history. " Really can't make up my mind so I'd really appreciate some input on this! Would the Nastrix be a as good as the Chinese clone, or is this a scam? I should mention that the seller has 100 % positive feedback.
- 6 replies
- 1
- 6498
- chinese clone
(and 3 more)
Tagged with:
