Over tightened Casebacks
The times I notice the screw caseback has been tightened completely up and is difficult to release.
I can understand this on a dive watch where compression has to be considered, for diving but in all other circumstances, isn't necessary.
All that is required is a sufficient seal between the case and gasket i. This is done before the final thread and the gasket in partial compression is assisting to lock the case back in place.
And when removal of the back is required again, it's an easy task.
Think of your house when you turn the water supply off. When you turn back on , you turn the valve handle all the way back and then quarter turn back. This helps the thread becoming stuck.
When I replace the caseback I use one of these which is sufficient to keep everything in place and a water tight seal for most occasions, certainly for a desktop diver
I don't agree that using a ball to close a case back is sufficient or good practice. At the minimum, a Jaxa tool. That is the typical tightening I find on new Seiko watches, and on occasions I need to use the real thing to open divers.
Experimentation required. Take the movement out of one of your skx's. Replace crown and caseback with a ball. Submerge in water, even give it a shake and see if you find any water ingress.
Also with Seiko, can't speak for others, haven't tested. Unscrew the crown, Submerge in the same way if the seals are good, will be very surprised if you find any water ingress.
To be honest, since I've bought the tool, I'm much less inclined to do pressure testing... because the sink is in another room [emoji3]
I've only got the sink [emoji4] I was referring to watches used for general day to day use. If I was going in the water I would screw down but for my own peace of mind rather than a practical necessity.
Also I noted Seiko use a dedicated flange on their dive cases for their gasket. Which is far superior to a watch without.
Any diving everything should be tighten. Some people believe at depth. Movement creates additional pressure. Which is true but the human body would have to be swimming at 50mph to make a significant difference
I don't even believe to watches for diving, forum threads on the subject are *so* repeating. One sentence I care to avoid is "desk diving", for some reason it gives to my nerves. But I did dive with a bottle (not beer) once, and it was amazing. If I were to do it again I would probably wear one, but only because I would  neglect to leave it in the room, but be worried to have it stolen if left on the boat.
All that being said, my daily beater is a dive watch. I blame that on my customers corrupting myself.
Edited by jdm
  • 2 months later...
Just to update. Though the watches that I mentioned previously showed no visual signs of in letting water.
Now I have a pressure tester
Out of 4 of the watches tested just using the ball to fasten the case back, 3 failed a 3 atm pressure test !
They were fine once screwed fully home.
An additional test on a Rotary 3 piece case with a snap back that at some point in it's life had been mullered. Also I have replaced the crystal, passed the test with flying colours . I expected this watch to fail.
In conclusion I've changed my opinion as just using a ball to tighten, even on a watch used daily in dry conditions, as potentially moisture could still ingress.
From the above, a watch that is of value, it's well worth having it tested and changing gaskets at the appropriate service interval18cb5b04846e6174d42bd35e554157b7.jpgbe04ea254c932ff64af9061854c538ba.jpg
I mean using moderate force, a case back should never be that hard to remove. I would say definitely use a Jaxa or similar to do the final tighten/first loosen. There's no problem with using the jaxa and doing it a bit tighter than the rubber ball can do, the problem is some technicians out there seem to think it a strong-man competition and are completely reckless with how much they tighten it. Reasonable, moderate, controlled force (Which I get is a nebulous concept) is all you need, no grunting or panting or gauging the case back, no spraining your wrist, etc.
I've taken notice that, when working on omega and tag watches that I knew were last worked on at a tag/omega workshop, that the technicians don't even tighten them as much as I would. but certainly, they don't come off with a rubber ball.
Edited by Ishima
When trying to open a case back that is too tight I'll use one of the metal tools but if the small holes/gaps on the case back are made in such a way that my tool will slip I actually try my best to use the rubber ball so as to not scratch the case back.
Takes a bit of time and effort but it works. Not always but better to try and insist a little than scratch the case.
When screwing it back in place I usually use the rubber ball and then the tool to tighten it.
If the watch is not really water resistant (below 200m WR, no screw down crown) then I won't tighten it as if it's supposed to go into the Mariana Trench.
Aloha digginstony ,
I splurged earlier this year and got this puppy . I believe I got it at the make offer price of $224 .00 and free shipping .
Man , I love it . From China , Yes ,...but very well made ....all machined and fitted parts .
59a6271ce65f6_ScreenShot2017-08-29at4_42_29PM.thumb.png.8ad863f29373f39ecbd07014499515b6.png
http://www.ebay.com/itm/TOP-Big-head-High-Quality-Watch-Case-Opener-Watch-Open-Tool-watchmaker-tools-Set-/221278174618?hash=item338534fd9a:g:9kcAAOSw~FNUacGd
The first watch I opened was a vintage Seiko that must have been cross-threaded and stuck with super glue guck . I had been trying to open it for a couple of weeks using my jaxa tool , penetrating fluid , coaxing it by putting it in one of my case holders that can clamp down to my desk so it won't move and tapping the jaxa notches trying to unscrew it ,...all to no avail . After letting the penetrating fluid sit overnight on a few occasions and then tapping all around the case back with a small rubber and neoprene headed hammer , once again , No Dice .
So I went ahead and got this super nifty case back opener, set the watch in the nylon holders that fit , adjust , and hold the watch between the lugs . turned down , fine adjusted , and locked in the jaxa type fittings in this case to the notches ,and Voila ,...I turned the large top wheel and had no problem opening the case back . No slipping , no scratches or gouges . Just smooth as butter .
I have since opened a variety of case backs including Rolex as this tool comes with the openers that fit the tool .
More pricey then a Jaxa tool , but I can easily recommended it .
Aloha digginstony ,
Aloha
I have a similar case back opener. My issue was with the amount of force required to open some backs that came into my possession and why were they tightened to such a degree ?
I did some tests with a ball, which initially seemed favourable but had no means to check the watches under "Stress".
I acquired a water pressure tester and as already stated had a 75% failure rate using a ball as a means of securing a water resistant seal.
Therefore I withdraw my original comments on the efficiency of using a ball as a means of attaining a water resistant seal.
Also I find your type of case back opener to be "Best" and certainly more efficient than a jaxa. Though this could be down to faulty manipulation [emoji4]
1 hour ago, digginstony said:
Just a word of caution. When buying from abroad, certainly from the UK. Some of these deals are not so great, once you've paid VAT + Import duties + handling fees from the Courier service.
At this time, UK buyers pays no additional VAT or duties of any type when buying from the EU. And Chinese sellers are helpful with declared value.
4 hours ago, vinn3 said:
most mechanics  will "over tighten" !  that is why a torque  setting is required.     this is for installing back or for measuring "over torque".  vinn
Really no need of over-complicating things. Not even the zealous Swill tool makers offer such a contraption.
Before you folks are going to buy via eBay buy directly from China and save the brokerage fees. Go to AliExpress and scroll through this search and search it yourself as well. BTW: don't buy any of the cheap stuff, from my experience it's just waste of money.
Edited by PJA
Thanks , JDM mentioned this site on Aug . 30
I buy from AliExpress for about 5 years now and it's basically like the Chinese version of Amazon, although they've got some issues of trust with the rating I have found, roughly, in general, the more expensive stuff is okay and in case of a problem I usually file for a dispute. in fact, now many sellers on Amazon and eBay are selling with direct shipping from A.E. with the seller's name on the invoice, so you can't even tell (A.E. has this program now). So, anytime you will see China on eBay and Amazon or 30 days shipment it must be a hint. I actually have just received my new Timegrapher about an hour ago from them and about to unbox it.
Edited by PJA
4 minutes ago, vinn3 said:
thanks for  re mentioning the  " China site ".    N ow if  someone has a " direct from Russia site". i would try it.
In fact many Russian buyers on this site. But once again I must stress that they try not to publish or hide negative customer reactions, so it's another place to shop on but keep your guards as well.
Edited by PJA
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
