Shock Spring for Bulova 11 AL
Hey all. New to the forum and to watch repair.
I'm working on reviving a 1965 Bulova 11 AL. It was not running when I got it, and after a clean and oil, it's now running pretty strong*. However, in the process of stripping it down, I did break the shock spring on the mainplate. I was lucky enough to find a replacement on eBay, which is on its way, but as I did a test on a similar one, I ended up breaking it on removal. So, I'm obviously not very good with the things. I've attached photos of where the eventual one will go, as well as a photo of what I bought (spring in tact).
Any advice on the best way to remove and then install these? Any help is appreciated.
* I say running strong, only when facing up, as the lack of stone (which I still have) on the other side keeps the balance from spinning when upside down.
Thanks,
Seth
You can buy proper tools for this type of work. If you have a good cleaning machine in many cases, it is not necessary to take them apart.
I expect some on here will be very eager to criticise my info.   :D
Thanks OH and Rogart63. I think the decision I will have to make is whether it's easier/safer to try to remove the spring from the donor mainplate and then install it in my watch, or just swap everything over to the donor. I'd prefer to just swap the spring, but after breaking two of them, I'm a little nervous.
Thanks for the other thread. I did indeed see that, it just didn't give any master tips for removal. Probably because there aren't any master tips. But the covering in film/rodico for installation is helpful, as is your graphic for removal.
As for cleaning, I can't afford the space or money for a cleaner, so am doing things by hand. Hopefully next time I can just get the stone out for cleaning without breaking the spring or needing to remove it completely, which is obviously a pain.
I wanted to follow up that I successfully removed the spring from the donor plate and got it installed in my Bulova. It's now running whichever way it's facing and I'm quite pleased. Thanks for the help here. I also found this video:
https://www.youtube.com/watch?v=HiAh4TkN25s
Which was a huge help, mostly in giving me the confidence that it wasn't impossible. It definitely was trickier for me, but I got it in:
I did employ the technique that I found elsewhere here to lay a layer of cling wrap between me and the movement to prevent a fly away spring. It ended up not being necessary, but made me feel a lot more confident.
Well done Seth. Trading via this site is not permitted, but if you are in the uk and advertise the remainder of your donor movement on ebay, you might find that someone would buy it to obtain a clutch wheel :-)
Is it a trade if I just give it to you? DM me your address if that's not a violation. Unfortunately, however, I'm in the U.S., so you'll have to wait for me to get an international stamp, plus travel time.
    • I dont like to give up things that i enjoy Tom.  So my next question is how are we going to prepare for that inevitability and what are we going to do about it. Its not just about funding it but I did pick up on something that Mark said once. It doesnt run on fresh air , what if it becomes a burden or an unnecessary cost or for any other reason that i wont get into. We all know life can change in an instant, my life has been so up and down for about 8 years and was only just beginning to level itself out.
    • What I especially like is that this forum is not full of ads. There are some but they're not interfering. No ads between posts like one certain big watch forum. Browsing is also very easy and light for a mobile device. I'm glad there's still room for old school forums like this. I'm a member in many facebook groups but there's really no long term discussion and if you see an interesting post you might never find it again if needed.
    • Hey, Nick! Thanks for sharing your beginning attempts in watch repair and welcome to WRT. I am familiar with the Citizen and the Sekonda. Likely the Citizen houses a Citizen cal. 8200A and the Sekonda a Poljot 2614.2H. I have serviced several of both and made a service walkthrough of the Citizen which you find if you click here. There's a lovely story about the Poljot movement on TimeZone.com called Jessica’s Cornavin Dolphin. Good luck!
    • A perfect example Hector, with the forum we would lose so much more My sentiments exactly Richard, i have experienced  that loss already,  Tiny, Gert, Galilea to name but a few all of which i enjoyed conversations with. I imagine it keeps a lot us sane OH.
