Zenith 120 train wheels
Zenith 120
Hi,
I have just serviced a Zenith 120, with centre second hand. The problem is, when all the train wheels are in place and all other parts, barrel, keyless and motion works. The watch will wind and run, but when the crown is pulled to change the time, the train wheels lock up totally. Is this something to do with the Hack feature, or have I assembled it wrong, perhaps two pinions are opposing each other..
I have been servicing for 4 yrs and have not come across this before. The third wheel has the double pinion.
If anyone has a service schedule for the 120, or has a solution, I would greatly appreciate the help.
Keith
yes it does and holds tight. If I take the pressure off slightly with an oiler it allows you to rotate the hand wheels, but in only one direction.
There is something in opposition somewhere.
I cannot be the only one to encounter this problem, surely. :(
Edited by Legarm
Sorted it. The intermediate drive wheel for the minute cog is meant to be a friction fit enabling it to rotate. Some one had crimped it on so hard, it wouldn't turn. Stripped it an reamed it out slightly. Now working a treat.
Never worked on a Zentith movement. But sounds like you found the problem. Is it like on some Omega movement that has a cannon pinion on the third wheel?
I have worked on a few Zeniths, but not one with this type.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
