Mainspring
Can someone tell me, I just put a new mainspring in a barrel by hand, because I don't have a spring winder yet. My question is this, how do I wind it enough to get the spring to engage the barrel arbor?
This is a size 12 american pocket watch
Thanks
Also make sure you have put the spring in the barrel the correct way so it will engage with the hook on the arbor.
It's an easy mistake to put it in the wrong way, something I have been guilty of doing in the past........
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
