No answers on threads?
With the risk of opening a can of worms? Why are there so many new questions that the OP doesn't answer. We try to help out as good we can but no feedback from the starter of the thread. Makes me mad and sad  and don't want to answer any more questions. Whats the good for the forum i the OP doesn't answer our questions or get back if he finds out himself or if he gets the answer on an other forum?
This is not  specific to any member. It's just in something i have seen lately.
Yeah, there are people who have a thought or question, hop on their phone and ask in a forum or two, and then lose interest.
I knew someone who would start his post with "Dear Lazyweb - " when he thought he was doing that.
Usually these folks are clueless and don't realize how aggravating their behavior can be to the folks in the communities who try to help.
I try to answer as many as I can, but my field is more about clocks.
Don't worry I've got a few clocks in the post and a few more waiting for me to start on.
Over the coming months I plan to ask questions about early 20th century French carriage clocks, Kundo anniversary clocks, US Navy Seth Thomas deck clocks, National time recorder clocks and if I get to them Russian military clocks too. :D
Yes I do have far more clocks waiting for me to get to than is healthy.
I would like to say to other members feeling disheartened about not getting replys from original posters take heart in the fact that many other people read your posts too and your post probably ends up helping several other people too that may not even be members of the forum, you may never know it, but your post has helped spread knowledge
That is so thru. And that helps me going and keep me answering. But as i don't now that much about clocks i seldom answer those particular questions.
I try and answer as many as I can with the knowledge I have. However some questions I don't because I did not have the knowledge and do not always have time to do the necessary research. Some questions are repeated such as "what lubricants should I use" "what is the best starter kit" etc but the answers to these can be found by simply using the search bar.
It is annoying sometimes when answering a question but no feedback is given whether the answer helped.
  • Like 7
Hi all, I find the people on this forum are really helpful and knowledgeable and every question I have asked has been answered within 24hrs. I always try and reply to everyone and I hope I haven't missed anyone and if I have missed anyone, thank you. Johnnie
Everyone starts with that first post, some will get the answer they need and we'll never hear from them again. Others will get the 'bug' and develop their knowledge and skills. These guys in turn will be sharing their skills.
My take is, it is impossible to separate the wheat from the chaff. The supply of 'affordable' watch repairers is an ever dwindling number. The people who are studying in watch schools will not be looking at servicing Seikos etc at a price the regular watch collector can afford. Less people are being 'apprenticed' to a watch-maker to learn the skills.
Watch repair is not a black art. All that is needed is (a) bit of mechanical aptitude, (b) patience and (c) someone to point you in the right direction.
So if someone has (a) and (b).... this forum (and Mark's tutorials) can provide the (c).
but we won't know from the initial post..:thumbsu:
Anilv
Edited by anilv
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
