No answers on threads?
With the risk of opening a can of worms? Why are there so many new questions that the OP doesn't answer. We try to help out as good we can but no feedback from the starter of the thread. Makes me mad and sad  and don't want to answer any more questions. Whats the good for the forum i the OP doesn't answer our questions or get back if he finds out himself or if he gets the answer on an other forum?
This is not  specific to any member. It's just in something i have seen lately.
Yeah, there are people who have a thought or question, hop on their phone and ask in a forum or two, and then lose interest.
I knew someone who would start his post with "Dear Lazyweb - " when he thought he was doing that.
Usually these folks are clueless and don't realize how aggravating their behavior can be to the folks in the communities who try to help.
I try to answer as many as I can, but my field is more about clocks.
Don't worry I've got a few clocks in the post and a few more waiting for me to start on.
Over the coming months I plan to ask questions about early 20th century French carriage clocks, Kundo anniversary clocks, US Navy Seth Thomas deck clocks, National time recorder clocks and if I get to them Russian military clocks too. :D
Yes I do have far more clocks waiting for me to get to than is healthy.
I would like to say to other members feeling disheartened about not getting replys from original posters take heart in the fact that many other people read your posts too and your post probably ends up helping several other people too that may not even be members of the forum, you may never know it, but your post has helped spread knowledge
That is so thru. And that helps me going and keep me answering. But as i don't now that much about clocks i seldom answer those particular questions.
I try and answer as many as I can with the knowledge I have. However some questions I don't because I did not have the knowledge and do not always have time to do the necessary research. Some questions are repeated such as "what lubricants should I use" "what is the best starter kit" etc but the answers to these can be found by simply using the search bar.
It is annoying sometimes when answering a question but no feedback is given whether the answer helped.
  • Like 7
Hi all, I find the people on this forum are really helpful and knowledgeable and every question I have asked has been answered within 24hrs. I always try and reply to everyone and I hope I haven't missed anyone and if I have missed anyone, thank you. Johnnie
Everyone starts with that first post, some will get the answer they need and we'll never hear from them again. Others will get the 'bug' and develop their knowledge and skills. These guys in turn will be sharing their skills.
My take is, it is impossible to separate the wheat from the chaff. The supply of 'affordable' watch repairers is an ever dwindling number. The people who are studying in watch schools will not be looking at servicing Seikos etc at a price the regular watch collector can afford. Less people are being 'apprenticed' to a watch-maker to learn the skills.
Watch repair is not a black art. All that is needed is (a) bit of mechanical aptitude, (b) patience and (c) someone to point you in the right direction.
So if someone has (a) and (b).... this forum (and Mark's tutorials) can provide the (c).
but we won't know from the initial post..:thumbsu:
Anilv
Edited by anilv
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
